Can not access stereo after replacing battery
Old Jul 28, 2010 | 11:34 PM
stanwelks's Avatar
I replaced the battery in my 2006 TSX and when I turned it back on, I entered the NAV code and it asked me to leave the engine running while in park so it could pick up the GPS signal. It indicated it could take a while. I let it do it for a couple of minutes, though I had to leave, so it did not finish.
The GPS seems to work fine now, though I can not access the stereo. When I click on the audio button, nothing happens.
I have restarted the car several times and have no access to the stereo and it is not prompting me for the audio code.
What do I need to do?
Thanks!
Old Aug 2, 2010 | 11:34 AM
Jimmy The Saint's Avatar
does it show code on teh radio display (above the nav screen)? It should then enter the code as per the owners manual
Old Aug 2, 2010 | 01:34 PM
nj2pa2nc's Avatar
it's a car-drive it
Thanks!
the nav and the radio have different codes-the radio had 5 numbers-use the tuner botton on the radio turn to the appropriate #'s. For the first 4 correct #'s CODE will show up then you put in the 5th # and push in the tuner button.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Gianni Formica
Sep 7, 2015 08:28 PM
