bustin fuses
The Power of a Grill
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
Ok, I need some help here. I installed dom's tv/nav converter a few months ago along with all the other necessary hardware and a pocket dvd player. I get an Ipod nano for my b-day and bought a car-charger for it. one day (within a week of using the charger) i notice that the charger does not work anymore in the usual spot of within the center console. I check it on the "not an ashtray" plug and it works fine. Then, the fuse blows. whatever i try, i blow a fuse. sometimes it will work out fine for a few minutes and then blow. Ive checked each wire and tried with a new fuse - im at about 10 now. The only fuse that blows is the 15w power to the power points. because dom's unit is powered, when i dont get power to the unit, i dont get power to the navigation screen and it is useless. I can guess where the buttons are and it will work, but i get little or no picture. now my setup is as follows:
Doms unit, Power filter and dvd player (under navi) running through power from power spot next to "not an ashtray" the power goes to the filter and then over to (split) converter and dvd player. the P.I.E. sound box is not powered.
I have checked out all the connections behind the dash and everything seems good. Oh, one more thing - the passenger side heater light is out now and will not turn on. Not the little red lights, but the background lighting that turns on when you turn your lights on. The other one is fine.
Am i pulling too much power from the outlet? It was fine until just recently. I dont think i changed anything else recently except for the ipod adapter. but now it wont even work w/out the adapter. I checked fuses in the dvd player wire and the ipod adapter, they are both fine. i am very frustrated.
any help would be appreciated
As for the reset of them, check the plug for the iPod in another car. Sounds like the plug might have an issue.
Originally Posted by moda_way
This isn't b/c of your electronics. I have only a Sirius system and my bulb went out. It is a defect and covered.
do you think it would help to unplug the battery and rework the power/ground wires?
Check and make sure there is nothing metal in the socket, like a paperclip or something. I was blowing fuses with my cell charger until someone on this site told me that most blown fuses from power sockets are caused by metal f.o.d.
Rep'n Taxbrain.com
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
Rep'n Taxbrain.com
Originally Posted by CGTSX2004
Send a PM to resident electronics guru, Elduderino. He should be able to give you an idea of what might be going wrong.
Unfortunately, Eld has kind of dissappeared from the forum. He doesn't post in the audio/video section anymore and I've heard he doesn't really return PMs anymore. Last I heard he's been really busy with his new car stereo shop. Hopefully he comes back some time.
It sounds very possible that there is to much current draw from the "not an ashtray"socket.
It sounds like that is where you are gettin the power source from for your new navi system correct?
If so, it may be fine for the fuse to have that draw for the navi etc., but when the iPod is connected it draws just that much more through that will blow the fuse for that socket. Try goin to a higher amp fuse again 20amp maybe, and see if it still blows.![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
Its almost like stickin a whole bunch of house plug power strips together with a bunch of appliances....something will give
Originally Posted by Tsx536
Hey What up CG...nice to see you back man ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
And that's unfortunate to hear about Eld. He was very knowledgeable in this area so his expertise would certainly be welcome in this sort of a situation.
Ok. i found a fucking penny in the center console plug thingy. Now when i get off work i will go and buy yet another fuse and test it out. I should have looked there first. Thanks all
![what](https://acurazine.com/forums/images/smilies/what.gif)
That'll do it.
my fingers hate me
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
after work, i went to a convenience store (i get out of work at 11pm and all the auto shops are closed) and bought a fuse kit, stuck in the fuse, and it blew. wtf???? now im wondering, did i undo one of the connectors during the 2 am wire checks last time? why isnt this working anymore? i am soooo frustrated. I gave up last night. will try one more time today before work before i toss this car in the dumpster and start over.
then again...
Fixed. turns out the fuses weren't blowing anymore after the penny was discovered. well, they were but not because of the load. the power wire to the power filter was disconnected after my rage-like wiring on the last try before i found the penny. it was touching the metal cage for the oem extra player (tape, mp3, dvd) and was shorting out. I reconnected and crimped, now everything works fine and both outlets are juiced. thanks for everyones help again. I know that i can always find an answer to my car problems here eventually.
Acura604
20
08-05-2017 12:55 AM
xsilverhawkx
09-28-2015 06:51 PM
ripit
09-26-2015 06:19 PM
