bumper spacing/gap opening by headlamp
Old May 26, 2008 | 05:57 PM
xjohnkdoex's Avatar
where is my garage?!
hey all,
i noticed this weekend that i have a widening gap by where the bumper/headlight/fender all meet, specifically with the bumper edge.
originally, i thought someone might've backed into me, but i didn't see any visual scuffs/damage indicating i got hit, although it's still a possibility (love tap). even if i did, i'm not sure i understand how that one section would pop out.
the other theory i had was maybe someone was trying to pry open my car to get my HIDs, but i didn't seen any confirmation of scratches.
so i'm kind of stuck as to the cause, but what i'm really looking for is a solution. i tried pushing the section of my bumper flaring outward back in to possibly click-in any clips that may have loosened, but nothing clicked. in fact, the main big tab seems like it's hooking onto the clip like it should. after pushing, there still a pretty big gap. more than the right side of my car.
what i think i'll do is probably remove the screws and bolts on that side of my car so i can just peel back that part of the bumper and try to push it back on and see if it sits flush like it should. otherwise, are there any sort of fixes to close the gap if the tabs end up being in the right spots and clicked in? this thing is bothering the hell out of me. i've attached some pics of the gap and section of the car in question. thanks.
Old May 26, 2008 | 06:21 PM
curls's Avatar
Someone stole "My Garage"
That is strange. Any other panel gaps where a plastic and a metal panel meet? Could be deformation caused by heat, but the heat would have to be pretty extreme, and in NYC the only heat is from the hot air people talk around there.
I'd think that one of the more minor clips/pins might have come out somehow, either during a love tap or just because of vibration on the road. If you feel up to it, take the bumper off and check (have one or two spare clips on hand just in case)...
Or stop by a decent bodyshop and see if they can tell just by looking at it -- they see this kind of stuff all day and have more experience than I.
Old May 26, 2008 | 06:30 PM
xjohnkdoex's Avatar
yeah, i thought if heat was a factor, but it really hasn't been that hot the past few days.
could it be the actual headlight housing? i tried to look at both sides to see if maybe the headlamp was depressed further in than the other, but i couldn't really tell. it looks ok to me.
i think i'll end up just peeling that part of the section of the bumper off for a look, but i was just curious to see if anyone else has ever had this issue. i think my last resort will be a body shop. i kinda want to avoid having to pay for a fix if i can diy it.
Old May 26, 2008 | 06:53 PM
aaronng's Avatar
Driver/Detailer
It sags.... if you take the bumper off, you'll see the hooks that hold the bumper up. Mine is a 5m gap now. Enough for small lizards to crawl through.
Old May 26, 2008 | 07:58 PM
xjohnkdoex's Avatar
lol. yeah, i've noticed the general sag. but this is more like someone decided to pry it open, then stopped.
does victoria's secret make the best push up braw for modified front bumpers of TSX's yet?
Old May 26, 2008 | 11:13 PM
bo0sty's Avatar
i thought the gap under my headlights was un-natural, is there anyway to fix sagging, would like to have a tighter fit around headlights.
Old May 27, 2008 | 08:21 AM
xjohnkdoex's Avatar
the sag/gap is normal.
but the gap in the pics i posted...that's not. even with sag, that corner piece shoulddn't flare out like that.
Old May 27, 2008 | 08:39 AM
acn684's Avatar
since u live in nyc, someone either hit ur car gently enough not to leave a mark, or even sometimes pedestrians in a rush just running into ur bumper.
Old May 27, 2008 | 08:45 AM
nj2pa2nc's Avatar
it's a car-drive it
maybe one of the clips snapped-same thing happened to mine-noone hit it-the dealer replaced the clips, free of charge.
Old May 27, 2008 | 08:58 AM
xjohnkdoex's Avatar
you can replace those clips? i thought it's just hooks grabbing onto bumps there?
there's one hook that you can kind of see right under the light in the 1st pic. that's on.
the only thing i can come up with is that the rest of the little hooks to the right of that...the ones closer to the tip popped out and is sliding under where it should be. which is why when i press down, nothing snaps in b/c it's not going into the seam it's supposed to hook/clip into.
i f'ing hate SUVs. my brother-in-law said i was pretty much jammed in between 2 when i parked at the hospital b/c my wife and i had to bring our son in for some emergency treatment.
the irony is, when we left, some stupid garage had left their business card for 'collision repair.' i almost thought that they did the damage then left the card for me.
Old May 27, 2008 | 10:36 AM
inkonspikuos's Avatar
ink
Interesting that it's the heat. I live in Miami, Florida and I have the same issue. I only noticed the gap happening only under the head light. It just keeps growing and growing and...
Old May 27, 2008 | 11:04 AM
xjohnkdoex's Avatar
i'm not attributing this to heat. it can't be. if it is, then i'm taking it to the stealership for warranty service.
Old May 27, 2008 | 02:36 PM
xjohnkdoex's Avatar
a buddy of mine suggested that the polyurethane warped b/c it was possibly squished by someone backing into my car, holding it, then moving forward.
can that even happen? i mean, i know it bends. but why would that 1 corner bend outward?
god, this is so annoying to think about. i need fix this somehow.
Old May 27, 2008 | 04:39 PM
Mike_E's Avatar
2004 Acura TSX
I have the same problem.... weird. I've never taken apart my bumper...
Old May 27, 2008 | 04:57 PM
CGTSX07's Avatar
looks like the aftermath of an accidental tap w/o any surface damage.
definitely try to peel that side of the bumper off and reassemble it.
Old May 27, 2008 | 06:51 PM
visuelz's Avatar
East Coast Crew
Try retightening the screw at the wheel well.
Old May 27, 2008 | 07:42 PM
ink
So the what can cause the gaps that I'm having?!! Does anyone else have them?
Old May 27, 2008 | 08:18 PM
xjohnkdoex's Avatar
the gap under the headlights are normal. if you look at other TSX's, they have the same issue.
Old May 27, 2008 | 10:39 PM
visuelz's Avatar
East Coast Crew
Hmm, I took apart my bumper when I installed the front lip. There's square plastic piece that we might be able to replace to close up that gap. Hmm...can anyone confirm this? I really hate the gap on one side of the bumper.
On other note, does anyone have dust inside their headlights? If so what's the best procedure to clear it?
Old May 28, 2008 | 01:50 PM
neninfgoo's Avatar
6th Gear
Wink good,support
My Gift To You, including a lot
Good,and tell us funny thing!
Remember these are averages, and the
has been in a drought for some time. Old timers in
Prescott will tell you how almost every afternoon in July and August they got their almost like clockwork.
They still get quite frequent short showers but for the last few years they have not been as regular
escort shanghai-shanghai female agencies escort
metal etching-metal etching help you to power
etching machine-etching machine help you to power
massage shanghai-Relax web site from massage in shanghai
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
rhdune16
Sep 28, 2015 11:31 AM
