Brakes and vibrating...
Old Jun 29, 2005 | 11:57 AM
euroStyle's Avatar
for those of yous who've had the problem. was it covered under warranty? miles on your car?
My dealer said warranty didnt cover the brakes, but im at 20k.
Old Jun 29, 2005 | 12:34 PM
moda_way's Avatar
I know a few have had them covered. I replaced mine because I new it would just happen again with those OEM rotors.
Old Jun 29, 2005 | 02:06 PM
euroStyle's Avatar
did you put in aftermarket ones?
if so, which would you recommand?
Old Jun 29, 2005 | 02:25 PM
Viking's Avatar
Quattro in.....
Check out his thread https://acurazine.com/forums/showthread.php?t=23558
Old Jun 30, 2005 | 01:19 AM
Alin10123's Avatar
Take it into another dealer. Bumper to bumper means just that.
On the other hand, if it was worn down pads in 20k miles then i could say it doesn't cover wear and tear. But warping rotors is not a problem that is considered wear and tear. If it was too thin to machine or whatever, that is wear and tear. But not if it warps.
Try another dealer.
Or... you can go aftermarket if you want to.
Old Jul 10, 2005 | 07:48 AM
dsusseles's Avatar
8th Gear
squeeky brakes and vibrating
I too, had a vibration in the brakes while slowing down from highway speeds(65mph). I took it ot the dealer and it was fixed under warranty (22k miles).
Old Jul 14, 2005 | 02:07 PM
weapon-x's Avatar
Just had mine done under warrenty yesterday and I'm at 20k as well. They resurfaced the rotors and replaced the pads. You may want to try another dealership.
Old Jul 14, 2005 | 03:38 PM
euroStyle's Avatar
which dealership did you go to?
Old Jul 14, 2005 | 05:59 PM
miner's Avatar
Had my rotors turned at no cost during my 30000 maintenance
Old Jul 14, 2005 | 08:41 PM
weapon-x's Avatar
Tustin Acura
Old Jul 20, 2005 | 06:59 PM
atlatr's Avatar
This was an ongoing problem with me......After taking my 04 in twice the dealer on the third visit for the same problem replaced the pads themselves instead of just resurfacing the rotor. Worked like a charm......I presume they put higher temp pads in place of the OEM crap.
Old Jul 24, 2005 | 03:03 PM
Weck's Avatar
That blowed up real good!
I've had this vibration problem since the car has been 1 month old. I always assumed it was just crappy, undersized brakes. After reading this post I took it to the dealer - they machined the rotors under warranty. Problem fixed.
Anyone's problem resurfaced after the fix?
BTW, they inspected the pad and found virtually no wear after 40K (kms).
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
