Blinking "P" light and static noise coming from gear shift area
Old Jan 6, 2019 | 05:22 PM
T/S/X's Avatar
6th Gear
2005 Acura TSX......I replaced my brake light switch and still doing it....Sometimes (every 2 -3 days )or so the park indicator light will flicker & i get a static noise in the gear shift area...The car runs fine, just had new brakes all the way around, new power steering unit , plugs & drive belt change....Car runs good..any ideas?
Old Jan 6, 2019 | 06:30 PM
Ron A's Avatar
Administrator
Welcome to the forums.
Since this is a topic/technical issue which will require replies, and not a "New Member Introduction", this thread has been moved to the model specific forum.
Old Jan 6, 2019 | 06:42 PM
T/S/X's Avatar
6th Gear
Sorry, i'm new
Old Jan 27, 2019 | 05:12 PM
T/S/X's Avatar
6th Gear
Replaced the brake light switch behind brake pedal, still doing it....Anyone here with an idea?
Old Jan 29, 2019 | 09:57 AM
TexasHonda's Avatar
Transmission range switch is likely. See attached file for testing.
good luck
Old Jan 29, 2019 | 07:30 PM
T/S/X's Avatar
6th Gear
Thanks, where is that located?
Old Jan 30, 2019 | 09:38 AM
TexasHonda's Avatar
Transmission, usually accessed from driver's side wheel well. see attached for replacement.
good luck
sphilli80907
Oct 12, 2019 03:57 PM
wusty23jd
Aug 8, 2018 02:47 PM
Alaa22
Oct 28, 2015 12:03 PM
Megs04TL
Jul 9, 2015 02:33 PM
marcelo
Jan 19, 2013 07:09 AM
