Better secure the intake crank case connection?
Old Oct 15, 2008 | 02:58 PM
Thermos's Avatar
Can I just replace the circled parts (in the pic below) with a straight hose from the intake to the crank case? What is the point of that little plastic box there? It's a weak connection due to the angle that puts strain on it and it often becomes loose and seems to restrict airflow if anything. Am I missing something here?
Old Oct 15, 2008 | 04:32 PM
curls's Avatar
Someone stole "My Garage"
I had the exact same thing happen on my Injen intake a few years ago. It just so happens that one day while at the dealership, the tech took a piece of suitable-sized hose and cut it to the right length, running it from the box to the crankcase/valve cover. It's never moved since.
The problem w/ the design is the little rigid tube that I can see in your pic (light-grey colour). It has no ridge to hold a hose + clamp and thus, the hose slips off. Just remove the rigid plastic piece and replace with any suitably-sized hose, you'll be fine.
cycdaniel
Dec 17, 2019 10:58 AM
joflewbyu2
Oct 8, 2015 11:16 AM
navtool.com
Sep 25, 2015 05:15 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
