Another O2 problem...
Old Mar 27, 2008 | 01:05 AM
euroStyle's Avatar
I was having issues like excited was...
https://acurazine.com/forums/showthr...primary+sensor
and finally got a CEL, but only stayed on for 2 days and it went off.
So i took my car into the dealer, knowing it was probably the O2 sensor gone bad.
After checking out my car, they said it was a P0171 code. and recommended i change and/or service my "aftermarking", comptech icebox, or air filter, K&N.
So i bought a new K&N filter and still having the same issues.
And is my problem the cause of primary or secondary sensor?
What are the difference between the two?
Since it's coming out of my pocket, should i just ask them to replace the O2 sensor?
Old Mar 27, 2008 | 08:14 AM
moda_way's Avatar
P0171 is usually associated to another code per AllData on our car. My guess is one of a few things... you don't have a good seal with the Comptech & K&N option. You are doing the weatherstrip seat with the K&N right? Additionally, you might want to look at putting and anti fouler on your O2 sensor. Go to Autozone, buy a set, drill it out with a 1/2" bit almost to the bottom and reinstall with the O2 sensor. Don't recall if you are running an aftermarket cat or not. You'll need the least obvious antifouler you can get due to CA air nazis.
Old Mar 27, 2008 | 12:09 PM
euroStyle's Avatar
I don't have the weather seal on it, but did something else to keep a good seal on the comptech lid. But im going to put on my stock lid.
And i'm running stock on pretty much everything else.
Old Mar 29, 2008 | 03:23 PM
euroStyle's Avatar
I think i found what's causing all my problems...
Old Mar 29, 2008 | 05:48 PM
PACman's Avatar
That is bent out of shape. I wish the designers would of included some sort of shield to protect this insertion site.
Old Mar 29, 2008 | 06:29 PM
euroStyle's Avatar
yeah.
And i can't believe the dealers said they've checked the sensors and didn't see that.
Old Mar 29, 2008 | 06:38 PM
PACman's Avatar
The sensor is a easy fix. Buy it online, then install it yourself.
Old Apr 4, 2008 | 10:28 PM
euroStyle's Avatar
Dealer wants too much for repair, i guess i'll be doing it on my own.
Will i need to reset the ECU after i install it?
Old Apr 4, 2008 | 11:55 PM
PACman's Avatar
^^You don't have to, cause after several days, the CEL will clear on its own. Or to make it happen sooner, you could disconnect the battery for 30mins.
Old Apr 6, 2008 | 10:48 PM
euroStyle's Avatar
Thanks for all the help.
Now to leave a bad comment on the dealership i visited.
Old Apr 6, 2008 | 11:43 PM
lcrazyaznl's Avatar
CL9 ABP
Buy the sensor from a wholesale that gets oem sensors cheap.
Hondaacuraworld. threw me the sensor a bit cheaper than dealer.
dealer was like 350
hondaacuraworld.com about 280 talk to tim (throw him an e-mail)
then you can do most of the install yourself.
Old Apr 6, 2008 | 11:47 PM
PACman's Avatar
36531-rbb-003 Sensor, Air Fuel Ratio 2004 Tsx $220.42
Old Apr 8, 2008 | 12:52 PM
euroStyle's Avatar
I got it from oemacuraparts.com, it was $202.
Old Apr 8, 2008 | 01:46 PM
PACman's Avatar
^^Good price!
danmm7
Jan 5, 2009 10:25 AM
Landocommando12
Aug 5, 2007 01:28 AM
Casper98CL
Aug 15, 2004 02:21 PM
Acura_CL
Mar 7, 2001 09:14 PM
