6 MY transmission moaning
I get a moaning sound from my transmission when I take off in first gear. If I get a perfect clutch release, I can avoid making the sound, but if I release the clutch too slowly, the transmission moans until I release, or press it back in.
Any thoughts?
Any thoughts?
Originally Posted by HMS/TSX
throw-out bearing, perhaps?
It is the throw out bearing! It will be replaced under warranty of course, but now I'm thinking...
As long as they've got the transmission opened up - should I spend $330 on a lightweight flywheel?
Anyone have knowledge on how much real-world performance gains I might obtain?
Originally Posted by fedlawman
Finally brought my TSX in for examination.
Originally Posted by xizor
does one exist is a better question
Comptech Flywheel
Originally Posted by joerockt
I've done some research over the last hour and it looks like a 10.5 lb flywheel will give some off the line acceleration gains, yet still be heavy enough to retain good driveability.
My only remaining doubt is that some articles have mentioned a drop in low RPM "torque" (caused by the loss of inertia) in exchange for high RPM gains - not exactly what the TSX needs.
I am having the same problem....Can someone tell me what the throw-out bearing is? The thread above is not working for me. Also, is this a problem that needs to be fixed immediatly?
thanks for you help!
joflewbyu2
Oct 8, 2015 11:16 AM
