2nd gear grinding and.....
Old Dec 22, 2004 | 09:49 PM
atlatr's Avatar
I thought I was just getting old and couldn't shift anymore but HAve come to realize that there might be a bigger problem here. I grind 2nd when under heavy acceleration. At first I thought b/c I was trying to shift so fast I was leting the clutch out too early, but after further testing/investigating I still know how to drive and am doing everything correctly. I can tell there is some resistance even when shifting slow from 1 to 2. Anyone else noticed this?
On another note I have warped rotors once again! This will be the 2nd time I have taken the car in for this. All they do is true the rotors on a grinding block. I would think this does nothing but make the disk thinner therefore more suseptable to warping.
Oh well
Happy Holidays
Todd
Old Dec 22, 2004 | 11:10 PM
TSX-2x's Avatar
5th Gear
Have the same problem on a brand new 05 when car is cold. I have to shift very slowly from 1st to 2nd to avoid grinding. But after the car warms up, I can shift as fast as I want and no grinding.
Old Dec 22, 2004 | 11:41 PM
fear's Avatar
I've always swapped out the stock tranny fluids for RedLine synthetics. Makes a WORLD of difference in the cold. Just make sure you match the viscosity and spec of exactly what is required. (i.e. if the manual calls for a GL-4 rated 75w90 then get exactly that and NOT a GL-5)
Old Dec 23, 2004 | 04:54 AM
sauceman's Avatar
Moderator Alumnus
About your "warped" rotors, it would be a good thing that you on how to break them in, and you might save yourself a fair amount of hassle if properly broke in.
Old Dec 23, 2004 | 10:43 AM
atlatr's Avatar
I broke the car in per the book 19 months ago when I bought the car. So I am sure that isn't the problem. I think we all know the brakes on the TSX are too small for the car.
This will be the first thing I upgrade if and when I do some mods....
Ciao
Todd
Old Dec 23, 2004 | 10:01 PM
Bass Mechanic's Avatar
you know i did that to my 93 honda civic i used redline MTL Manuel Transmission Lubercant. it looks a lot like auto trans fluid. anmyway after about 30K miles my bearings went in the trans and i had to have the tranny rebuilt because of a noise it started making. i dont know if i would trust that in the TSX
Old Dec 23, 2004 | 11:50 PM
fear's Avatar
That sucks. But I must say I've never had a failure with Redline in any manual tranny / differential or transfer case in 15 years across 9 or ten different cars and trucks(jap, american, german). And a few friends have logged about as much use as me with never a failure which is remarkable in itself. But it is very important to make sure you're using the exact type that your vehicle needs. A common problem is GL-5 spec fluid in a tranny calling for GL-4. Kiss those syncros goodbye....
Old Dec 24, 2004 | 12:19 AM
JTso's Avatar
I have seen reports on how Redline MTL ruins Honda tranny. It appears this good lub is not quite compatible with Hondas and many people have switched back to Honda MTL (myself included).
Old Dec 24, 2004 | 12:31 AM
gfxdave99's Avatar
6MT Snob
I get that once in awhile on mine, i KNOW the clutch is in but when i shift too fast to 2nd once in awhile i get a light grind... not the oh shit there goes my trans grind, but just enough to go.. ouch that musta hurt..
But on mine it doesnt matter if its cold or warm.. just when i get too agressive with the 1-2 shift...
Old Dec 24, 2004 | 09:26 AM
well i wouldnt exactly call it a failure. at first i heard this noise it sounded a little like a rattle. but it just didnt seem right. after having a tranny expert listen to it he positivly identified it as bearings.
it made a sound most people probly wouldnt notice, i dont know if i had let it go how long it would have taken to totally destroy the bearings. i did get a change to see them and the races were pitted.
the car had about 90K on it when this happend, that is a lot of miles but for the bearings to go on a tranny seems a little too remote to call it normal wear. the only thing i could come up with for a cause was the MTL, that stuff says right on the bottle its for motorcycle transmissions.
Old Dec 24, 2004 | 09:46 AM
atlatr's Avatar
This is exactely what I get.......
Old Dec 24, 2004 | 11:11 AM
JTso's Avatar
I think there might be a potential problem with the 6MT... I have experienced the similar grind but I originally thought it was caused by the short shifter that I've installed, throwing the synchronization off during shifting. I've been driving MT for years and personally don't think that I've messed up on the simple 1-2 shifting. It doesn't happen all the time or in any other gears.
Old Dec 24, 2004 | 03:15 PM
atlatr's Avatar
Problem
We should get a poll going to see what kind of numbers we got on this. If the majority of the people w/6MT's has this happen thenn there is a problem.
Old Dec 25, 2004 | 10:49 PM
97AcuraCL's Avatar
My bolonga has a 1st name
I get this problem with 5th gear. I took it to the dealership... they said I have a bad "synchronizer" in that gear only and that its not covered under warranty.... i'm fucked for $1300 <-- not a typo... They say its drivable just like that without fixing just that its going to be annoying... I'm broke after xmas... i'm jus gonna try to stay otuta 5th.
Old Dec 26, 2004 | 02:06 AM
gfxdave99's Avatar
6MT Snob
Not covered under warranty WTF? ????
Old Dec 26, 2004 | 10:28 AM
fear's Avatar
BullSh!t. They won't cover a bad 5th gear synchro? Absolute BS. It's not like someone would be slamming 5th.....
Go down to a good hardware store and pick up a bunch of small Grade-8 fasteners like tiny nuts and some machine bolts. Loose ball and roller bearings are the best if you have a good source. Dump a few of them into the tranny fill hole along with a few long squirts of engine de-greaser or brake cleaner.
Stay on back roads, keep a cell phone handy and get ready to clutch in fast....
Old Dec 26, 2004 | 10:42 AM
poltergeist's Avatar
Now there's a great way to make sure it won't be covered under warranty. I'd love to show that to our Honda rep after I'd torn down the trans. Instant customer pay only.
Also, the proper MT lubricant is Honda MTF. 5W-30 engine oil will work, but using GL4 or GL5 gear oil will make it even harder to shift and will eventually destroy the transmission.
Old Dec 26, 2004 | 10:47 AM
'92-2000 Civics are notorious for having the mainshaft bearing get noisy. As long as the oil you used in the trans was the proper viscosity, I doubt it caused your bearing failure. I think by design that bearing doesn't get enough oil splash.
these are exactly the kind of people i dont write insurance policies for.
always trying to get somthing for nothing!
your cool!
Old Dec 26, 2004 | 10:49 AM
well thats good to know but i still dont know if i feel comfortable putting MTL from redline in my trans.
to be honest i didnt really notice any better shifting in my civic when i tried it.
Old Dec 26, 2004 | 11:23 AM
I agree with you there. Best to stick with what Honda/Acura recommends.
BTW, I was in Dillon, Co a few months ago. What a really NICE place. The lake was so beautiful!!!!
Old Aug 17, 2007 | 12:39 PM
roguemoog's Avatar
I'm going to bump this up because mine is grinding into third gear if I shift above 4k. It used to be occasionally but the past couple of days, it grinds every time. I can feel it in the stick, and hear it, and even if I take my time shifting, it still does it.
But why are people saying that synchros aren't covered under warranty??? How can they prove it was caused by abuse? I don't abuse the car, in fact, because of this problem, I rarely shift above 5k.
If it's not covered under warranty, I am gonna be one pissed off SOB. I'm taking it in sometime next month as I have no time this week or next.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
