2004 TSX Noise--Help, what is it?
Old Jan 4, 2018 | 02:20 PM
texastsx04's Avatar
7th Gear
I purchased my 2004 TSX new and still have it with 120k plus miles. Since buying the car new, it has always made some sort of sound that is hard to describe coming from under the hood a few seconds after starting to drive. It is a hard noise to describe, but it is only a second or so long and has been the norm since I have owned the car. Recently, the sound has started to change. It is still very brief and happens every time I start the car and begin to drive. It sound more like a dry sound or almost a grinding noise. Yes, I am a female as you have probably already determined by my descriptions of this sound. If anyone can clue me in on what makes the normal sound and what could be going wrong now that it is starting to sound abnormal, I would REALLY appreciate it. Thanks for any help you may have!
Old Jan 4, 2018 | 02:27 PM
Since it's very hard to describe, could you possibly grab a video of it? you can upload it to youtube and post the link here.
what part of texas? I'm In houston and the cold weather is doing strange things 'round these parts. could possibly making the sound, weirder than when it was new?
Old Jan 4, 2018 | 02:35 PM
texastsx04's Avatar
7th Gear
good idea!
Great idea! I will record it and link it. I am in Austin and it definitely has been cold. I am fairly certain is has been progressively changing even before the cold started. We will be back in upper 60s -70s this weekend and will see that makes a difference. Thanks!
Old Jan 4, 2018 | 02:40 PM
I have a 2006 TL and there's a noise on start up, which we believe to be the fuel pump priming. it's present in all TL's. I've never started up a TSX before, but maybe the fuel pump is on its way out? i'm not to sure and just guessing until I can hear the noise.
also, when I changed the starter with a refurbished unit, it no longer sounded like a "honda" starter any more. but that wouldnt be the case for you, since you didnt change anything
Old Jan 6, 2018 | 12:00 PM
TexasHonda's Avatar
Power steering is notorious for startup noises (usually a whining or growling). Check PS fluid level.
good luck
Old Jan 10, 2018 | 02:00 PM
texastsx04's Avatar
7th Gear
Thanks! I suspected power steering fluid as well, so I just had it flushed, but issue still there. Here is a link to the sound. https://www.youtube.com/watch?v=B6c5...ature=youtu.be thanks!!!
Old Jan 10, 2018 | 02:01 PM
texastsx04's Avatar
7th Gear
Here is a link to a recording of the sound. https://www.youtube.com/watch?v=B6c5...ature=youtu.be Thanks in advance to anyone who has some insight into what the issue could be.
texastsx04's Avatar
7th Gear
Old Jan 11, 2018 | 01:58 PM
TexasHonda's Avatar
Hard to tell from the video. After listening several times the sound appears to me similar to a venting pressure relief sound I get from my 03 Acura MDX. It has always made this sound and I suspect is an Accumulator venting pressure but don't know. It only makes the sound on a cold start.
good luck
Old Mar 6, 2018 | 01:12 PM
H4L Kpassion's Avatar
Texastsx04, does the sound only occur once per drive cycle, meaning you hear it on take off like in your video and then not at all until next time you start it and drive it? If so, it may just be the ABS self test, or as texasHonda said, possibly a pressure relief valve.
Old Mar 6, 2018 | 01:13 PM
Is the noise occurrence affected by A/C being on or off?
steezyTSX
1G TSX Problems & Fixes
Sep 17, 2012 10:56 AM
MZCar
2G TSX Problems & Fixes
Nov 8, 2009 03:29 AM
overlord
Oct 15, 2004 04:02 PM
jrock65
Oct 8, 2003 12:07 AM
