2004 tsx headlight won’t come on after trying multiple things help!😔
Old Oct 29, 2023 | 02:17 PM
Moo-Cura's Avatar
My drivers side low beam light will not come on below is everything that has been done or replaced
1. new bulb
2. checked fuses, relay all are good but still replaced with new
3. Replaced igniter switch and then replaced new bulb with another new bulb
4. replaced the switch inside by the steering wheel
still nothing will work all other lights work on drivers side high beam, blinker, running light, but no low beam
the passenger side also works everything high, low, blinker and running
even checked to see if it was getting power with a tester at the bulb itself it works, just not in the car
Old Oct 30, 2023 | 09:57 AM
Swap the ballast from one side to the other to rule that out
bothanspy
Aug 19, 2020 11:10 AM
Debdeb15
Apr 25, 2017 08:30 AM
TL forever
Oct 23, 2005 12:39 AM
$peed])emon
Aug 27, 2005 12:23 PM
Da_iLLeZt_TL973
Aug 3, 2005 06:19 PM
