2004 tsx headlight won’t come on after trying multiple things help!😔
My drivers side low beam light will not come on below is everything that has been done or replaced
1. new bulb
2. checked fuses, relay all are good but still replaced with new
3. Replaced igniter switch and then replaced new bulb with another new bulb
4. replaced the switch inside by the steering wheel
still nothing will work all other lights work on drivers side high beam, blinker, running light, but no low beam
the passenger side also works everything high, low, blinker and running
even checked to see if it was getting power with a tester at the bulb itself it works, just not in the car
1. new bulb
Moo-Cura (10-30-2023)
I have new Osram bulbs installed and they both initially worked. Then they both were flaky and it would take 10-15 minutes of sitting and turning the headlight switch off/on until they both caught and stayed lit. I replaced both ballasts with cheap knockoffs (due to the ebay listing being a bait and switch). I installed the new ballasts and they both worked sorta. The drivers side ALWAYS comes on. The passenger side is still in the same loop of 10-15 minutes to get it to light up.
Da_iLLeZt_TL973
08-03-2005 06:19 PM
