04 A/C Issue
Old Jul 13, 2012 | 03:53 PM
himileage's Avatar
04 A/C Issue
Had an issue crop up recently on my TSX. My a/c blows ice cold on the passenger side but noticeably warmer on the driver's side. Wasn't much of an issue until the temps went through the roof, now it's almost unbearable. Sometimes when I back off the accelerator cool air will come through on the driver's side, but it doesn't last. Where should I start looking, the internal temperature sensor or the blend doors? Anyone else have this problem that they were able to fix? thanks!
Old Jul 14, 2012 | 09:56 AM
TexasHonda's Avatar
No regular AC systems (not individual temp control), this usually means the referigerant charge is low (stratified flow in evaporator w/ top warm and bottom cold). Additional refrigerant is the fix. You may want to do a leak check first.
good luck
Old Jul 14, 2012 | 05:43 PM
himileage's Avatar
good luck
thanks, i'll give that a try. that would be a cheap fixed.
Old Jul 17, 2012 | 09:02 AM
nbtx's Avatar
still plays with cars
I don't know if this system uses vacuum for the blend door - but your remark about cool when coasting ... ??? First have the high and low side pressures checked; it might just be low on freon per previous post.
Old Jul 23, 2012 | 06:42 PM
himileage's Avatar
a/c issue
took my car to a mechanic today as i'm not dealing well with the lack of a/c during the summer, turns out that a piece of debris had fallen from the cabin air filter and was stuck in the driver's side blend door. the blend door wouldn't close all of the way, leaving the air partially cooled and partially heated. problem solved and back to ice cold air again! until the compressor goes i guess LOL.
my mechanic said he recently had another tsx in the shop that had a blown compressor and the owner took it back to the acura dealer and they replaced it for free "under warranty". the mechanic said the car had over 100K so i guess he knew how to complain in the just the right way....
Old Aug 24, 2012 | 04:29 PM
gamekiller04's Avatar
How would I find blend door.. I have the same problem
Old Sep 11, 2012 | 08:32 AM
netsx04's Avatar
Does anyone know where to find this? I have the exact same problem of ice cold AC on passenger side and ambient/warm air on drivers side.
01CLOwner
Oct 9, 2015 01:07 PM
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
lovic87
Sep 15, 2015 06:07 PM
theinsvnity
Sep 10, 2015 10:22 PM
dlknight
Sep 3, 2015 07:54 PM
