Will this fit
Old Jan 26, 2005 | 12:27 PM
CCColtsicehockey's Avatar
Will this fit
Will this fit on our exhaust. I know I just replaced my exhaust and I should know and I personally think it will. I just was looking for some others point of view on wether or not it will fit. It looks a lot better than ours. Maybe it will cause better air flow who know but at least it will look better than the factory one which is all rusted up.
High Flow Cat
Old Jan 26, 2005 | 12:31 PM
JTso's Avatar
It's not a cat. The description said it's a test pipe or resonator. The only way you can make it work is to use a programmable ECU and run in open-loop mode.
Old Jan 26, 2005 | 12:54 PM
Could you explain that to me I am not sure what that means
Old Jan 26, 2005 | 01:39 PM
JTso's Avatar
A real cat has the catalytic honeycomb material inside the casing to remove harmful emissoin compounds. The factory ECU uses the secondary O2 sensor to verify the cat is functioning by the reading from the sensor. If you simply installed a test pipe or resonator in place of the cat, the sensor will signal the ECU to trigger a CEL. By using a programmable ECU, you have the ability to disable certain sensors monitoring.
Btw, by disabling the secondary O2 sensor, you should be able to return in closed-loop mode (normal) and allow the prmary O2 sensor to provide A/F feedback to the ECU for normal operation.
Old Jan 26, 2005 | 02:10 PM
so does this have any performance advantages.
Old Jan 26, 2005 | 04:29 PM
rmpage's Avatar
Drives With Hands
Cool, I've always been kinda curious about this. But while you're answering questions, what's a CEL? Thanks.
Old Jan 26, 2005 | 04:32 PM
cmf's Avatar
cmf
ATCer
Check Engine Light
Old Jan 26, 2005 | 05:26 PM
JTso's Avatar
As long as your stock cat is not clogged, I don't think you will see any difference in stock setup.
emailnatec
29
Sep 28, 2018 04:27 PM
vpasla1
Sep 17, 2016 07:24 PM
ROWDY621
Sep 30, 2015 03:20 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
Bielikb96
Sep 28, 2015 10:45 AM
