Trunk light install
Old Aug 14, 2006 | 05:33 PM
LoveMyTL-S's Avatar
Trunk light install
I just bought a 12" blue LED strip for the trunk. I'm gonna mount it toward the back and looking for a power source to tap into. I was thinking of the trunk light wires so it will come on when I open the trunk. But, which wire to tap into? The trunk light has two wires. One is light blue w/dark blue stripe and the other is white with a blue stripe. Which one is hot? Is the other ground?
Any help would be great!
Thanks..........
Old Aug 14, 2006 | 08:03 PM
LoveMyTL-S's Avatar
Nobody has a wiring book for the TSX? This would be really easy if I knew what wires to tap.. Any help would be appreciated.
Old Aug 14, 2006 | 08:18 PM
Reach's Avatar
So just tap them, and if it doesn't work, reverse it. I'm guessing the white one is hot from what i've seen of the tsx wiring, but that's just my guess.
Old Aug 14, 2006 | 08:27 PM
LoveMyTL-S's Avatar
Directions with the lights say to tap a 12v source and the other wire to ground. I may try what you suggest. Thanks for your input.
Old Aug 14, 2006 | 09:14 PM
JTso's Avatar
I would recommend at the very least get a multimeter if you are going to deal with anything electrical. It could save you from unnecessary grief.
Old Aug 14, 2006 | 09:43 PM
Reach's Avatar
Yeah, but hes not going to hurt anything with LEDs, so its fire ready aim if he wants.
Old Aug 14, 2006 | 10:34 PM
vidgamer's Avatar
Might as well use a multimeter and test the wires. They come in handy for all sorts of jobs. (I should put mine in my car in case I end up at the Jax meet....)
Old Aug 15, 2006 | 12:53 AM
Spoon's Avatar
Exactly. If it were a regular bulb, it wouldn't matter which is hot or ground. Current will only flow one way thru an LED, so if you hook it up and it doesn't light, reverse it.
Old Aug 15, 2006 | 06:50 AM
LoveMyTL-S's Avatar
Yes, I do have a multimeter. I was just wondering about those wires before I start stripping the plastic. Thanks for the input. I'm gonna tap off the current trunk light. If I have time I'll do it this afternoon. Vidgamer, I hope you make the meet.
Old Aug 15, 2006 | 09:24 AM
yuhoo22's Avatar
John Starks - The Dunk
you don't have to strip the wires....just remove the bulb from the existing and see which one is hot with the multimeter when you open the trunk.
Old Aug 15, 2006 | 12:13 PM
LoveMyTL-S's Avatar
Yea, I thought of that after I posted. The meter is new, so touch red lead to the socket and the black one to ground? Or the other side of the socket?
Old Aug 15, 2006 | 03:49 PM
xizor's Avatar
Bye TSX, hello domestic?
I looked it up since I have a lot of exp w/ the interior lighting after doing my puddle lights. pg 22-181 on the helm's
white/blue is 12v, blue/black is ground. you need to tap the power and ground so that your light is switched when the trunk opens
Old Aug 15, 2006 | 07:06 PM
LoveMyTL-S's Avatar
Sweet! Time to get to work.
Thanks Xizor......
btw, love those puddle lights. I printed the instructions today.
Old Aug 15, 2006 | 08:07 PM
LoveMyTL-S's Avatar
Okay, project done! Trunk light installed. Only took about 30 minutes. Here's a couple of picks.
Not real bright, but a subtle blue.
Thanks Xizor for your help......
Old Aug 16, 2006 | 08:27 PM
xizor's Avatar
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
