Short shift install
Old Sep 13, 2004 | 06:05 PM
batman's Avatar
Aint Doing Sh*t
Short shift install
I install a comptech shortshifter this weekend. It took way longer than it should have but I was trying to be careful. the center console was tough to take off. those clips are much more secure than in my accord. i got half way though and i couldn't get that safety clip that holds the shift cable so started using the neuspeed instructions. that worked out a lot better. For those that have done this is the shift cable supposed to be lower than before? I know you are adding to the shifter but it seems like they would design it so that it will be close to stack as possible. Also did it make your shifts harder? it seems like i have to force it into 5th sometimes.
Old Sep 13, 2004 | 06:14 PM
iamhomin's Avatar
04 remembrance
I actually heard it makes the shifting much smoother.
And by any chance, do you have the pictures of your installations?
Old Sep 13, 2004 | 06:20 PM
batman's Avatar
Aint Doing Sh*t
maybe I installed it wrong somehow. it may not be seat all the way. i am going to take it apart this weekend and do it over. i took some pictures in the begining but as i got more frustrated i stopped. if you know a site that i can upload them on i will.
Old Sep 13, 2004 | 06:25 PM
iamhomin's Avatar
04 remembrance
www.photobucket.com
www.imageshack.us
Old Sep 13, 2004 | 06:32 PM
batman's Avatar
Aint Doing Sh*t
i'll get them on there tomorrow
Old Sep 13, 2004 | 07:20 PM
xizor's Avatar
Bye TSX, hello domestic?
yes, remember there is a fulcrum, there extending the other end of the shift lever means less movement on the shifter side.
yes, simple physics would suggest that moving an object (linkage) the same distance with less shifting would require more force (w = F x d). my 5th is very easy, only 2nd is tough just because that's how the transmission is.
Old Sep 13, 2004 | 09:04 PM
Stokeless_TSX's Avatar
Stokeless
I like my comptech shortshifter =) i wish it would make it a lil shorter than it does though.
Old Sep 18, 2004 | 02:06 PM
LannyM's Avatar
Hondaholic
Two questions....
Does the Comtech Short Shift piece actually add to the shifter lever and raise it up a little bit, or does it replace something?
When you say you wish it was shorter, do you mean the height or the throw?
Thanks............
Old Sep 18, 2004 | 04:15 PM
xizor's Avatar
Originally Posted by LannyM
Two questions....
Thanks............
it makes the lever longer at the bottom, doesn't change the height of the stick at all. he means make the throw shorter.
Old Sep 18, 2004 | 07:38 PM
IneedaTSX's Avatar
Pics???
Old Sep 20, 2004 | 05:37 PM
batman's Avatar
Aint Doing Sh*t
here are some pictures. There is no real rhyme or reason to the way I took them. i was taking them so that i could remember what things looked like. I didn't take the cassing all the way off. I couldn't get that clip off. So i just reach under it. I didn't take a before shot of the shifter. i think that it lowered about an inch and half.
It took me a week to get used to it. Now I thinks its awesome. In two weeks i will install Comptechs Icebox.
Feb 25, 2020 09:57 AM
NitroViper
Mar 20, 2017 09:50 PM
BigJilm
Sep 21, 2015 08:32 PM
HOWELLiNC
Sep 5, 2015 03:09 AM
NSolace
Sep 3, 2015 08:14 PM
