K-Pro on a TSX engine (RSX swap)
Originally Posted by MrHeeltoe
2.4L versus 2.0L? I would think it would be better than a DC5R....we will have to see what numbers he gets with a TSX engine.
Originally Posted by JeffTSX
That's true but if the K24 frankinstien has the same reliability problems as the B20 frankinstien, I would stick with the DC5Rs.
Reliability problems? B20 VTEC does not have reliability problem if done correctly. It is only less reliable that a B18C if you beat the crap out of it....if reliability is lessened, it is not necessarily BAD....I think a properly built an maintained B20VTEC cam make gobs of reliable power better that countless other stock engine from other makes.
Likewise, what would be the problem with a K24-iVTEC? And what is the point anyway? a K24 converted to dual iVTEC is not going to be all that different from a TSX engine anyway, right? Just wondering....
A) A B20 block is different from a GSR or type R ONLY becuase of bore and the oil squirters. Deck height is the same, cylinders have the same construction, and obviously a VTEC head bolts right on. Other than internal components, the engines are VERY similar. Does your arguement mean that you feel LS VTECs are unreliable also?
B) .4L is a lot of displacement! Certainly worth the trouble if it will work. Torque makes a car fast, horsepower is a fluff number. MY question has more to do with your comment relating it to a B20 VTEC. True, the B20 VTEC is not something Honda offered from the factory, but a K24 with iVTEC was, and it is in our cars....so I am wondering, what is the big mechanical difference between a TSX engine and an Accord angine with a RSX-S head on it?
The RSX's engine is only 2L... it produces less torque, and it produces its max torque at a much higher RPM.
The RSX is only faster if its a Type-S, and its only because of the weight difference.
Originally Posted by RMATIC09
If im not mistaken, he put a TSX engine in his RSX? I thought the RSX engine was faster to begin with?
Originally Posted by TSX Cman
so other people can take our engine and have a great time with mods. and our egnine in our own car is much more difficult.
crazy system in a crazy world
Haha. That's a good thing about Hondas. Everything fits into everything!!!
Hey man, I think I was trying to draw a comparison that got messed up....
You said this:
"That's true but if the K24 frankinstien has the same reliability problems as the B20 frankinstien, I would stick with the DC5Rs."
All I meant was 2 things....
1) B20 frankenstien doe not necessarily have problems because of what it is....it may ecause of the builder.
2) Likening a K24 vtec to a B20 vtec might not be accurate. You are correct that a B20 never came vtec, but since a K24 does it could be totally different....like, maybe the K24 vtec is just like having a TSX motor....
cycdaniel
Dec 17, 2019 10:58 AM
justin7779
Dec 25, 2015 10:33 PM
