Interior LED problem
Old Oct 12, 2005 | 01:26 PM
kyotousa's Avatar
I swapped the map and dome light to LED yesterday
everything work fine...however when i turn the light off
it won't go off completely it will just become dimmer
it's not bright...but you can def. see the light still on.
anyone know how to fix this?
Old Oct 12, 2005 | 02:09 PM
say what?'s Avatar
set the switch to "door" instead of "off"....
Old Oct 12, 2005 | 02:14 PM
moda_way's Avatar
I have the same thing.. just set it to doors and I've had my LEDs in for a year or so.
Old Oct 12, 2005 | 02:29 PM
kyotousa's Avatar
yah...i know...but I am wondering any way to have it set on "off" and it would be actually off XD?
I don't want my map light to turn on when I open the door
Old Oct 12, 2005 | 02:52 PM
hawaiiantsx's Avatar
thats kinda weird...i switched mine and i dont have that problem...mines turn off fine...good luck with it...
Old Oct 13, 2005 | 12:34 PM
MikeZ's Avatar
8th Gear
Mine does that too. I installed the blue leds and noticed the map lights stay on when in the off position. Moving to "door" fixes it, but I wonder if it is still drawing some low voltage current in the off position?
Old Oct 13, 2005 | 01:53 PM
moda_way's Avatar
It very well could, but you could leave all your LEDs on and it wouldn't burn up your battery. They pull like 1/10th the power of a normal bulb.
Old Oct 17, 2005 | 02:27 PM
Adrena's Avatar
I installed the blue LEDs (5 lights kit - maps, dome and doors).
I started by changing the rear dome light then move to one of the map lights. When I open the door (checking that the bulbs worked), I noticed the dome light was just fading and not turning off. But once all three bulbs were installed (two maps and dome) - they all turned off completely. I had no problems with the doors lights.
Did you buy from Tech toyz?
Old Oct 18, 2005 | 04:29 AM
kyotousa's Avatar
yah i did......so you have no problem?
i have problem with all 3 lights 2 map and 1 dome light
how did you fix it?
Old Oct 21, 2005 | 09:12 PM
Adrena's Avatar
how did you fix it?
It fixed itself once all the lights were installed (3 lights: 2 maps & 1 dome)
Try playing around with the switch - turn from doors to off and back again....
I did play with the switches (both for map and dome) and I kept pushing the door switch to get the lights to turn on and off.
Good luck.
Sorry I'm not much help. =(
Old Oct 22, 2005 | 01:20 AM
kyotousa's Avatar
Good luck.
ic I am pretty sure you have all 3 on "door" switch then....
Old Oct 25, 2005 | 08:02 PM
Adrena's Avatar
I do.
What I meant is while I was installing the lights, they wouldn't completely shut off. So I had put the switches to "OFF".
But then once all the lights were installed, I put the switch back to "DOOR" and then they worked fine.
You shouldn't need to have the switch at "OFF"
Old Oct 25, 2005 | 10:21 PM
kyotousa's Avatar
I want to switch to off......
there's no problem if you switch all to "door"
I don't want map light to light up when i open my door
Old Oct 26, 2005 | 01:13 AM
Sebo's Avatar
then leave door closed and enter the car thru the window.
what difference does it make if they go on when you open the door?
Old Oct 26, 2005 | 01:55 AM
kyotousa's Avatar
why do you care if i don't like them to be on?
i just don't like them to be on...so i try to fix it......
so...why don't you post something helpful next time...maybe your next post will be "I always climb out through sun roof so there isn't a problem"
Feb 25, 2020 09:57 AM
oyayjoe
Jan 1, 2019 10:17 PM
handsom-hustla
Nov 13, 2015 05:04 PM
tiresmokinV8
Sep 15, 2015 09:10 PM
oyayjoe
Sep 12, 2015 04:40 PM
