I Need Brakes!!!!
Old May 31, 2007 | 10:31 AM
  #41
DjElucid's Avatar
Originally Posted by batman
Agreed. I replaced all my OE pads with Axxis on the stock rotors. All the vibrations and fading went away. I loved them!! The stopping power completely out weighs the excess dust. I need a set on my RDX now.
How often do you clean your wheels? I've been running the Axxis pads since Aug and I can't stand the dust. I'm planning on getting a new set of wheels and changing my pads because I would have to clean my wheels every week.
Old May 31, 2007 | 10:57 AM
  #42
jdepasqu2's Avatar
Wink
LIKE BATMAN SAID....., FOR ME STOPPING POWER AND LACK OF VIBRATIONS AND BRAKE FADE FAR OUTWEIGH THE DUST......, lIKE ISAID i HAVE THE hAWK HP PLUS PADS AND THEY REALLY ARENT NEARLY AS BAD AS I THOUGHT THEY WOULD BE....ITS BEEN NEARLY A WEEK AND i HAVENT EVEN SEEN MUST DUST AT ALL.
Old May 31, 2007 | 05:07 PM
  #43
aaronng's Avatar
Driver/Detailer
The dust doesn't bother me. A little liquid laundry detergent solution in a spray bottle and it all comes off with a little scrubbing with a soft brush.
Old Jun 4, 2007 | 06:58 AM
  #44
jdepasqu2's Avatar
its weird....., i have started to notice dust buts the dust is alot different than the oem pad dust...., the HP plus pads dust is alot lighter and dosent stick as much as the oem.... But non the less the dust is there and probably is more than oem but like I said I think alot blows right off and doesnt stick.. I havent tried washing my wheels yet but from just rubbing them with my finger...., I dont think that it will be that difficult to remove unlike the oem pad dust... my 2cents..........
Old Jun 20, 2007 | 05:13 PM
  #45
andeh's Avatar
8th Gear
Originally Posted by jdepasqu2
Exactly......., If you dont use an impact screw driver....., then you will defiently mangle the set screws (soft metal screws)..... As for the racing brake rotor holes for the set screws not lining up....., the front did but the back didn't...... But it dosent really matter the set screws just making installing a little easier...., and do not provide any other function.....obviously the lugs hold the rotor in place.....
Do you think I can do this without an impact screw driver, thereby mangling the set screws? Will I be able to get the screws all the way out with normal standard tools (plain old screwdriver) and then simply replace rotor and also replace set screws?
Old Jun 20, 2007 | 05:25 PM
  #46
aaronng's Avatar
Driver/Detailer
Buy an impact driver. It should cost less than $15. It's the one that turns when you hit the end with a hammer.
Pic from someone's personal website:
Old Jun 21, 2007 | 12:10 PM
  #47
andeh's Avatar
8th Gear
Thanks. I'll be picking one up from my local Sears for $19.99.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
