Got a couple hundred bux to spend....ideas?
Professional Newbie
Alright, so today is my birthday and I need a bit of help with things to get. I was thinking of getting some pedals from www.ultimatepedals.com but they would be over 100 for a full set, and that's a bit outrageous. So now I am getting brake caliper paint and some interior neon. My car is Carbon Grey with chrome rims, what color brake paint should I get? Also....I need the name of some good interior neon THAT IS NOT TOO BRIGHT
any other cheap mod ideas would be appreciated, but the color of the brake paint is the most essential question
Received 3,860 Likes
on carbon grey i would either do silver or black. i believe i am going to do mine in silver
Luke 1:37
Originally Posted by Tsx536
Happy Birthday man!
If you can be patient, I would just save it all for Hondata
I would get the M3 Replica Rear spoiler for $70 painted on Ebay.
Professional Newbie
nice edit there TSX536....I am doing hondata at the end of the summer, I have the money now, but want to make some more before i spend
Luke 1:37
Professional Newbie
Originally Posted by virtualbong
What about shocks and springs?
there's gonna be a lot happening between late august and november
there are definitely worse things for teenagers to waste money on
i started modding cars since i was 18.
its fun, but i dumped alot of money into it.
i wonder when i will finally stop.
Originally Posted by dzuy
i agree.
As for painted calipers I'd say no to it because our calipers got nothing to show. It's small, and not as beauty as Brembos or Stoptechs.
Rep'n Taxbrain.com
I see you reread his signature, LOL
....I almost got ed
Your Name is Max and My Name is Max, We both have TSX's, We both have the same birthdays and we both are 17!! wow!!
are u russian by any chance too? lol
Professional Newbie
nah, well...a bit russian, mostly hungarian
i dont want to tint my windows because then all the girls wont be able to see the sexy guy who is driving by
i think a lip spoiler is a good idea though....and just ordered some interior led modules (i think they are better than neon) for above the pedals and under the glove box
is there any DIY guide for installing that kind of stuff? I have no idea where to hardwire the power to...anybody know how to do it?
Professional Newbie
hmm....seems unanimous on hondata...but i really want suspension too....thats a toughie
and again, does anybody have instructions for hardwiring neon lights into the car?
even a generic guide will do
Luke 1:37
Get Hondata after saving a couple more bucks from our authorized vendor on here. You'll also want to get the heatshield gasket.
Rep'n Taxbrain.com
When do you want the neon lights to turn on? Were you planning to hook up an independent switch to do this, or where you trying to tie it an existing switch?
Professional Newbie
I'm going to install my own switch in one of the empty bays to the left of the steering wheel (next to VSA Off). However, I don't know where to tap into a power source around there
Professional Newbie
...in other words, does anybody know what power source under the steering wheel i should tap into? something safe that if it malfunctions wont make me crash
Rep'n Taxbrain.com
* Please note: I would not recommend this type of setup for anyone trying to hook up an aftermakert amp/head unit or anything that will be drawing a lot of power.
Here's picture of the fuse box in the TSX. Credit goes to Axygos, for this.
This pic and description was taken from this thread:
https://acurazine.com/forums/audio-video-electronics-navigation-22/sirius-sat-radio-install-287187/
For power supply, I didn’t want to damage or splice into any factory wiring… So I check out the fuse box and found some empty slots. The top row has empty slots that provide switched (ACC) power and the middle row has empty slots that provide constant power. The bolt under the fuse box is convenient to use as a ground. I used the Mini Add-A-Circuit that I bought at Auto Zone to place into the fuse box (I had purchased two of these before looking at the fuse box).
I would hook up the power wire to the Switched ACC power. This only receives 12 volts when the ignition is on, while the Constant is always receiving a constant 12 volts regardless of ignition position. You can think about the constant as being similar to connecting a wire directly to your positive battery terminal.
In order to prevent accidently leaving the neon lights on all night and draining your power, I would definitely tap into the ACC power and NOT the constant ACC.
You'll also need to integrate the switch into your setup. Depending on which switch you get, I can try to help you help with that too. Were you planning to get just a random switch at Autozone or were you going to try to get some type of Acura switch that is originally met for controlling something else?
Also, do you happen to know the basics of how a relay works?
You probably won't need one, but a switch functions in a similar way, so it may help you during the install.
Here's a good link that talks about them. Thanks to MusicBox for this link, wherever he is
http://www.bcae1.com/relays.htm
Professional Newbie
the lights are in!...sorta....i bought 6-LED modules and the one on the right is only illuminating 5 of them, and since i'm picky i'm gonna send it back for a new one, but the left side looks great and Add-A-Circuit worked flawlessly
AcuraKidd
09-25-2015 11:18 PM
