TSX High Beams
Old Apr 15, 2005 | 10:01 PM
HPower's Avatar
TSX High Beams
Hi I just bought a 2004 TSX. I love the HID's, but I noticed that my H1 stock highbeams are abnormally yellow coloured. I previously owned an 01 Jetta, and every aftermarket bulb I put in it always burnt out within a couple months. Thus, I am interested in any of you more experienced Acura owners know of good aftermarket bulbs, either bright white or blueish white, that last in the TSX?
Old Apr 15, 2005 | 10:15 PM
NightHawk CL9's Avatar
WAS HONDATAFIED IN
i used to have silvania silverstars in my previous car, and i was very happy with them. they are not blueish, but clear. also hoen seems to have a nice set, i think someone on here has them. i am interested in their foglights mainly, but they do seem to make highbeams too. but i really liked the look of the silver stars, they didn't make the car look like i wanted to be fake hid's like some blue lights. they were clear, and i might be picking up a set of highbeams for the tsx.
Old Apr 15, 2005 | 10:20 PM
minkl81's Avatar
Aftermarket bulbs are junks!!
PIAA or Silverstars lasts little longer but they all have short life span.
I had a 98 Accord three years ago and probably I spent $40~50 on a new pair of headlights every month because they burnt out so fast and some didn't even lasted two weeks. Tried Hiper, Nokya, APC, Eurolite, Silverstar, and PIAA. Among them Silverstar lasted as long as PIAA and was cheaper.
Get a HID conversion if you really want lights with long life.
But what is the point of changing high beam when it is not used often??
May be for the looks??
Old Apr 15, 2005 | 10:21 PM
jeffreytchui's Avatar
Delta Sigma Pi
I got Deep Yellow H1s if you cant beat em join em
hehe
Old Apr 16, 2005 | 01:04 AM
rmpage's Avatar
Drives With Hands
I got the PIAA H1's. Very white. 4300K - stock HID color. Not sure how long they actually last though.
If you want to do the HID conversion, you can get a H1 conversion kit for about $400. For a bulb that is almost never used it is not worth it IMO. Also, you use the high beams to flash other cars. HID's don't flash well because they can be damaged by sharp transients of current which produces heating/cooling spikes in the gas and drastically reduces lamp life. Same reason stadium lighting takes almost an hour to restart once power is interrupted.
Basically I suggest getting some PIAAs or Silverstars. You'll be pleased.
Old Apr 16, 2005 | 06:49 AM
TSX7's Avatar
I replaced my H1s about 2-3 weeks ago with Silverstars. It's not an exact match (HID=4300K and Silverstar=4000k) but it's better than the stock. If you look at it during the day, there's a big difference between them but at night they seem to match better. I'm not sure if it was worth it. Haven't been on the highway since I got them so I don't know how well they light up the road.
Old Apr 17, 2005 | 04:47 PM
gavinn58's Avatar
STi'd
hehe
Can you post pics of these bulbs on your car? I've been thinking of getting the Piaa Ion Yellow bulbs for my high beams. I had the ion yellow for my fogs on a 2000 accord and loved the look with a retrofitted HID kit.
Old Apr 17, 2005 | 05:32 PM
rmpage's Avatar
Drives With Hands
How are the yellows for driving though? After using HIDs I can barely stand the spectral quality of wannabe-white halogens, so I can't imagine what using a deliberately yellow bulb would be like. Basically I'm wondering how good they are for driving, despite the JDM look or whatever.
Old Apr 17, 2005 | 05:41 PM
gavinn58's Avatar
STi'd
IMO, they didn't really make much of a diff. from a lighting standpoint. With the fogs, there was just a yellow hue on the ground. I'm assuming since these will be high beams it will be noticeably brighter and probably will not use them as much. TBH, I'd just be getting them for looks.
Old Apr 18, 2005 | 10:50 AM
slats's Avatar
Phillips "blue vision" bulbs are supossed to be good.....
Old Apr 18, 2005 | 12:31 PM
HPower's Avatar
-i think i tried those phillips bulbs a while back and they were terrible. A lot more yellow than blue. Nothing compared to the silverstars I had on my jetta, and they aren't even that white..
Old Apr 18, 2005 | 12:43 PM
drunkenbuda's Avatar
Got Phó?
CATZ are the way o go...to bad they don't make CATz anymore...
Old Apr 18, 2005 | 11:59 PM
Delta Sigma Pi
Old Apr 19, 2005 | 12:02 AM
Delta Sigma Pi
My HIDS are not stock. 6000K..they arent as bright as the 4300Ks but they look 100 times better!
Old Apr 19, 2005 | 01:12 AM
Andynolife's Avatar
i bought a set of jap aftermarket blubs for my EuroR foglights .. and it's still working great .. and haven't have any problems for almost an yr now .. and i turn it on everytime when it gets dark ~ and they r almsot as bright as the HID
Old Apr 19, 2005 | 09:29 AM
CJams's Avatar
Guinea Pig
You may know this already.......but just in case.... when istalling these bulbs you should not touch the glass with you bare hands at all! If you do, they will blow out prematurely for sure! Happens every time! They last 1/8 as long with your finger grease on them.
Old Apr 19, 2005 | 10:17 AM
slats's Avatar
I read on the net that all aftermarket HID kits are illegal for street use, is that true?
Old Apr 19, 2005 | 10:39 AM
rmpage's Avatar
Drives With Hands
As long as you install them correctly they are fine.
Old Apr 19, 2005 | 12:05 PM
leftride's Avatar
i want to ride my bicycle
but it doesnt look like most manufactures are making them correctly:
http://www.dot.gov/affairs/nhtsa4304.htm
Old Apr 19, 2005 | 02:31 PM
gavinn58's Avatar
STi'd
I had a huge glare issue with my aftermarket kit on my Accord, but I thought it's usually due to the reflector housing being made for halogen lighting as opposed to HID lighting.
Old Apr 19, 2005 | 08:25 PM
slats's Avatar
What year accord?
Old Apr 19, 2005 | 09:05 PM
Muthafaker's Avatar
8th Gear
Old Apr 20, 2005 | 11:31 AM
gavinn58's Avatar
STi'd
2000 v6 coupe. I see a couple people from the v6p boards here. Apparently we had the same idea when the tsx came out.
Old Apr 21, 2005 | 07:40 AM
Shockme66's Avatar
High Beams on Only!
Is there any way to turn just the High Beams on without the HID's going on?
Thanks.
Old Apr 21, 2005 | 09:32 AM
HPower's Avatar
Yep, already knew that. But thanks for the help anyways.
Old Apr 21, 2005 | 01:24 PM
TSX7's Avatar
Thanks.
All Canadian cars have day time running lights (just the high beams) so I'm assuming you can do it to your TSX.
IBankMouse
Jun 13, 2020 12:53 PM
jriv7
May 8, 2020 05:50 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Sep 21, 2015 08:44 AM
theinsvnity
Sep 10, 2015 10:22 PM
