Engine Water Lock!!!!!!
that little tupe connect the middle of the intake back to your engine or part of the engine right?
i just put it where the stock tube goes, and i have experimented taking it off. doesnt make a difference to me.. But if i were u, i would just connect it bak to where the stock ones are, leaving a hole there will suck in dust and or contaminant gradually and it would be too hard to try to seal that thing 100% tight. so no worry, its nothing that will blow your engine.. just put it back to where the factory put it, and you will be fine..
If you're going to decide to go with an SRI, you better also get a Hondata Heatshield (it's an intake manifold gasket that keeps your actual intake air cooler). Otherwise, you're just sucking in more of the seriously hot engine bay air. Who cares if your CFM is increased if your increasing the heat level?
i say get the icebox
Originally Posted by gsclifton
how is the icebox any different from the injen? wouldnt i still need a valve for that too? ive also heard theres a diff in performance b/w the icebox, any SRI, and the injen with the injen being better.
rockyboy
08-04-2024 10:35 AM
