Engine Water Lock!!!!!!
Old Aug 5, 2005 | 04:06 PM
mesherm's Avatar
Anybody know how well a water bypass valve really works? I want a cold air intake but i sure as hell dont want my engine water locked. Is it worth 50 bucks or not???? HELP!!!
Old Aug 5, 2005 | 04:18 PM
mesherm's Avatar
Anybody????
someone has to know about these things
Old Aug 5, 2005 | 04:19 PM
Howard911s's Avatar
HOWARD911S
ha. i used to do it all the time. the bypass... but im poor at explaining it ....
Old Aug 5, 2005 | 04:21 PM
mesherm's Avatar
can you at least tell me if its effective????
Old Aug 5, 2005 | 04:23 PM
Dan Martin's Avatar
Photography Nerd
The bypass valve loses a couple HP from what I've read so you should just go SRI if you're worried about hydrolocking.
Old Aug 5, 2005 | 04:25 PM
Howard911s's Avatar
HOWARD911S
that little tupe connect the middle of the intake back to your engine or part of the engine right?
i just put it where the stock tube goes, and i have experimented taking it off. doesnt make a difference to me.. But if i were u, i would just connect it bak to where the stock ones are, leaving a hole there will suck in dust and or contaminant gradually and it would be too hard to try to seal that thing 100% tight. so no worry, its nothing that will blow your engine.. just put it back to where the factory put it, and you will be fine..
Old Aug 5, 2005 | 04:42 PM
gsclifton's Avatar
ABP TSX
Bypass valve
If you are really that worried, get the Comptech Ice Box or something in SRI mode.
Old Aug 5, 2005 | 04:44 PM
GIBSON6594's Avatar
My Garage
I used to worry about locking up too...don't. Just be careful around oceans
Old Aug 5, 2005 | 04:48 PM
Xtremespeed2102's Avatar
the TSX isnt a dune buggy for a reason
Old Aug 5, 2005 | 06:59 PM
LoveMyTL-S's Avatar
I have an Injen CAI and I've been through some deep puddles and not problems.........
Old Aug 5, 2005 | 09:31 PM
mg7726's Avatar
She said: it's GINORMOUS!
just remove the resonator. hp gains right there.
Old Aug 5, 2005 | 09:56 PM
kurt_bradley's Avatar
If you're going to decide to go with an SRI, you better also get a Hondata Heatshield (it's an intake manifold gasket that keeps your actual intake air cooler). Otherwise, you're just sucking in more of the seriously hot engine bay air. Who cares if your CFM is increased if your increasing the heat level?
Old Aug 5, 2005 | 09:59 PM
dzuy's Avatar
Troutslap Mod-DUH-rator
i say get the icebox
Old Aug 7, 2005 | 09:04 AM
mesherm's Avatar
Originally Posted by gsclifton
Bypass valve
how is the icebox any different from the injen? wouldnt i still need a valve for that too? ive also heard theres a diff in performance b/w the icebox, any SRI, and the injen with the injen being better.
Old Aug 7, 2005 | 11:10 AM
Savio's Avatar
TSX
debadge
rockyboy
Aug 4, 2024 10:35 AM
01CLOwner
Oct 9, 2015 01:07 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Sep 14, 2015 10:09 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
