Comptech Flywheel
Old Aug 5, 2004 | 08:41 PM
TSX007's Avatar
Comptech Flywheel
Just read on another site that Comptech is releasing a chromoly flywheel any day now
for the TSX for those interested. No details yet. Source: Nate from Comptech.
Old Aug 5, 2004 | 08:45 PM
sauceman's Avatar
Moderator Alumnus
Oh!!! Now this will get interesting...
Old Aug 5, 2004 | 09:08 PM
Stokeless_TSX's Avatar
Stokeless
hmmm i wonder how much will it weight and i also wonder how much will it cost hehehe
Old Aug 5, 2004 | 09:09 PM
accsuperstar's Avatar
http://honda-tech.com/zerothread?id=948364
Old Aug 5, 2004 | 11:05 PM
xizor's Avatar
Bye TSX, hello domestic?
I'm offended they would post on honda-tech, their TSX forum is probably the most dead one on the entire site.
Old Aug 6, 2004 | 12:15 AM
tony4311's Avatar
I am Ahab!
so what. He's a member there so he posted. You would rather he not post it any where? He probably won't sign up to this site(IF he even knows about it) just to post that as spam.
It'd be better for him to stick to one site that caters to ALL the cars they make parts for.
Old Aug 6, 2004 | 12:17 AM
tuan209's Avatar
wht does a flywheel do?
Old Aug 6, 2004 | 01:28 AM
Stokeless
your kidding right?
Old Aug 6, 2004 | 01:34 AM
jmathew34's Avatar
The flywheel helps the engine's crank shaft maintain momentum and aids in idling. A heavier flywheel will aid in torque (pulling power and acceleration), while a lighter flywheel will aid in top speed but may cause trouble with engine idling.
also might want to check this link out. great website for how things work, helps me out.
http://auto.howstuffworks.com/transmission5.htm
Old Aug 6, 2004 | 01:49 AM
tuan209's Avatar
Originally Posted by Stokeless_TSX
your kidding right?
hahaha....no im not. im a total noob to all this car mod stuff.
Old Aug 6, 2004 | 02:11 AM
xaznperswaesonx's Avatar
umm .. never knew heavier flywheel will aid the torque, from what i know from centrifugal force is that if a heavier flywheel will take longer to spin up to the same speed as a ligher flywheel and vice versa. heavier fly wheel is more towards gas efficiency i blieve b.c it taks longer for the motor to decelerate, hence your car travels a bit further then a lighter flywheel.
i could be wrong.
pretty much ligher flywheel lets your needle gets to red line faster than a heavier flywheel. and since it's an acura/honda motor .. we alllll love that!
Old Aug 6, 2004 | 05:26 AM
sauceman's Avatar
Moderator Alumnus
i could be wrong.
Old Aug 6, 2004 | 10:13 AM
cmf's Avatar
cmf
ATCer
So what would be some CONS of getting a new, lighter flywheel?
Old Aug 6, 2004 | 10:27 AM
Dan Martin's Avatar
Photography Nerd
Assuming it's designed correctly and weighs enough there shouldn't be any. If it's too light or poorly engineered you can sometimes get gear rattles or rough idling. Lighter flywheels can also make it easier to stall your car.
Old Aug 6, 2004 | 10:36 AM
TSX007's Avatar
I Don't think we'll be running into those problems with Comptech.
Old Aug 9, 2004 | 11:16 AM
dagigu's Avatar
yup! comptech products == no worries
Old Aug 9, 2004 | 11:20 PM
Stokeless
im hoping for about 8-10 lbs for the new flywheel i wouldnt want to go much lighter than that when im going under boost.
Old Aug 10, 2004 | 01:03 PM
daddydliv's Avatar
Faster, please.
I weighs 10.5 lbs. and retails at $349 USD. They are in stock right now. That is probably a good weight (I don't know what the stock weight is) as a friend of mine has a CRX with a 7 lb. flywheel and has rough idling.
Old Aug 10, 2004 | 04:36 PM
TSX Cman's Avatar
350 USD for a flywheel... whoa
not used to that, anyone think it would be worth the dollar?
Old Aug 10, 2004 | 05:02 PM
TSX007's Avatar
anybody know the weight of the stock flywheel?
Old Aug 10, 2004 | 07:41 PM
dorikin_86's Avatar
i could be wrong.
Just in case you guys are intersted:
T = I x A where T= Torque & I = moment of inertia and A = angular acceleration. In order to increase A, you either increase torque or decrease I. In this case, a lighter flywheel = lower I value therefore it will help you achieve faster flywheel spool up and hence faster acceleration off the line. I don't think it helps with top end speed though...
Old Aug 10, 2004 | 07:49 PM
DEI99662's Avatar
I guess you do learn something new everyday. Thanks a lot!
Old Aug 10, 2004 | 10:06 PM
tsXgtp's Avatar
Sile
$350 isnt bad for a flywheel considering its the first on the market.
It won't increase top speed. Only change the gearing will do that.
I think this thread tried to get a little too complicated. A lighter flywheel has the same effect lighter wheels do. The lighter, the more acceleration. The effect is more dramatic @ the flywheel than the wheels b\c the fly is connected right to the crank.
Old Aug 10, 2004 | 10:10 PM
Dan Martin's Avatar
Photography Nerd
Also the engine is way more responsive when you've got the clutch in and trying to match revs.
Old Aug 11, 2004 | 01:26 AM
Stokeless
im gonna get one but im gonna wait for some clutches to come out first might as well replace both while i have the tranny out =)
Old Aug 11, 2004 | 01:31 AM
CGFebTSX04's Avatar
would the flywheel only apply to manual transmissions or could it also be used on auto transmissions?
Old Aug 11, 2004 | 03:03 AM
gavinn58's Avatar
STi'd
I'm also looking out for a clutch. Anyone here drove an STi? I loved how the clutch grabbed on that car. No slippage at all and very short pedal travel to the floor.
Old Aug 11, 2004 | 06:07 AM
sauceman's Avatar
Moderator Alumnus
Only on manual trannies. On an auto trans, it's just pretty much a flimsy disc weighing barely 1lb.
Old Aug 11, 2004 | 12:10 PM
dzuy's Avatar
Troutslap Mod-DUH-rator
cool. my friend has a fidenza flywheel on his integra type r, the needle shoots with a minor blip in the gas, but yea, you have to give it more gas or will stall out.
makes the car a lil harder to drive in the city, but not much
Old Aug 11, 2004 | 12:23 PM
xizor's Avatar
anyone think the flywheel might not play nicely with the DBW? Since the DBW gives some slight throttle when you let off the accelerator, would the revs shoot way up w/ a lightened flywheel?
Old Aug 11, 2004 | 12:25 PM
dzuy's Avatar
probably not that bad. maybe a couple hundred rpm, but i wouldn't be worried about it.
Old Aug 11, 2004 | 09:12 PM
daddydliv's Avatar
Faster, please.
I'm also gonna wait for a more compatible clutch to become available since the flywheel will probably rip the stock clutch apart. I got all giddy when I heard the news but have to remember I'm driving this thing everywhere, everyday.
I am, however, doing a few mods in the coming weeks - Injen CAI, Hondata Gasket, Comptech Short shifter, and Comptech rear sway bar (Sorry I'm gittin all giddy agin!)
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
k6biv
Sep 22, 2015 02:06 PM
TxRzrBk
Sep 17, 2015 01:07 PM
