Comptech Flywheel
Comptech Flywheel
Just read on another site that Comptech is releasing a chromoly flywheel any day now
for the TSX for those interested. No details yet. Source: Nate from Comptech.
Originally Posted by xizor
I'm offended they would post on honda-tech, their TSX forum is probably the most dead one on the entire site.
It'd be better for him to stick to one site that caters to ALL the cars they make parts for.
Originally Posted by tuan209
wht does a flywheel do?
also might want to check this link out. great website for how things work, helps me out.
http://auto.howstuffworks.com/transmission5.htm
Originally Posted by jmathew34
The flywheel helps the engine's crank shaft maintain momentum and aids in idling. A heavier flywheel will aid in torque (pulling power and acceleration), while a lighter flywheel will aid in top speed but may cause trouble with engine idling.
i could be wrong.
pretty much ligher flywheel lets your needle gets to red line faster than a heavier flywheel. and since it's an acura/honda motor .. we alllll love that!
Originally Posted by xaznperswaesonx
umm .. never knew heavier flywheel will aid the torque, from what i know from centrifugal force is that if a heavier flywheel will take longer to spin up to the same speed as a ligher flywheel and vice versa. heavier fly wheel is more towards gas efficiency i blieve b.c it taks longer for the motor to decelerate, hence your car travels a bit further then a lighter flywheel.
i could be wrong.
i could be wrong.
Originally Posted by cmf
So what would be some CONS of getting a new, lighter flywheel?
Originally Posted by Dan Martin
Assuming it's designed correctly and weighs enough there shouldn't be any. If it's too light or poorly engineered you can sometimes get gear rattles or rough idling. Lighter flywheels can also make it easier to stall your car.
hmmm i wonder how much will it weight and i also wonder how much will it cost hehehe
i could be wrong.
i could be wrong.
T = I x A where T= Torque & I = moment of inertia and A = angular acceleration. In order to increase A, you either increase torque or decrease I. In this case, a lighter flywheel = lower I value therefore it will help you achieve faster flywheel spool up and hence faster acceleration off the line. I don't think it helps with top end speed though...
Originally Posted by dorikin_86
Just in case you guys are intersted:
$350 isnt bad for a flywheel considering its the first on the market.
It won't increase top speed. Only change the gearing will do that.
I think this thread tried to get a little too complicated. A lighter flywheel has the same effect lighter wheels do. The lighter, the more acceleration. The effect is more dramatic @ the flywheel than the wheels b\c the fly is connected right to the crank.
Originally Posted by CGFebTSX04
would the flywheel only apply to manual transmissions or could it also be used on auto transmissions?
cool. my friend has a fidenza flywheel on his integra type r, the needle shoots with a minor blip in the gas, but yea, you have to give it more gas or will stall out.
makes the car a lil harder to drive in the city, but not much
anyone think the flywheel might not play nicely with the DBW? Since the DBW gives some slight throttle when you let off the accelerator, would the revs shoot way up w/ a lightened flywheel?
I'm also gonna wait for a more compatible clutch to become available since the flywheel will probably rip the stock clutch apart. I got all giddy when I heard the news but have to remember I'm driving this thing everywhere, everyday.
I am, however, doing a few mods in the coming weeks - Injen CAI, Hondata Gasket, Comptech Short shifter, and Comptech rear sway bar
(Sorry I'm gittin all giddy agin!)
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
