Attempting IceBox Install - Question
According to the CompTech instructions, the entire resonator and stock intake tube is removed. Is this true? I am having a heck of a time trying to get this thing out. All the bolts are removed but it's just not coming out. Am I not supposed to remove the entire intake system? Any insight appreciated. BTW, I do not have the entire front bumper removed and am attempting to go through fender well.
from what i've read, you can remove the resonator by removing the tabs and peeling back the wheel well (front left tire off). the bumper removal is not necessary, although it's been said it makes everything a lot easier, particularly removing certain bolts.
here is a diy of an injen CAI install....there's a comment about removing the resonator and how it needed some pulling.
here
here
here
here
Thanks again...
Originally Posted by CarbonGray Earl
The bitch bolt.....did you get the bolt that's accessible through the foglight hole in the fender? That's hidden from view, and can be missed sometimes.
Originally Posted by CGTSX2004
The resonator splits into two pieces. You'll have better luck getting it out if you remove the wheel.
OK, I got it using gental brutality...lol! Seriously, It does end up in three pieces as described above. I just needed to use a little more muscle to pull it free. Thanks all for your quick replies...hope I can help you sometime!
is the 'bitch bolt' harder to access for 06/07's since the fog light is in the way?
just curious. b/c i have an 07 and i'm planning to install the icebox as well.
That's a good Q. I didn't have foglights on my 05, so it was as simple as removing the foglight placeholder.
RoodHawg - good stuff man.... when in doubt, just yank it out!
underneath...doh! i have no jack stands. should i put the tire underneath as a precaution?
i gotta install my icebox too...should i just remove the front bumper? I tried helping my friend on his 05 and it took 3 hours to just remove that one bolt...which we ended not removing that night.
I have an 06 so im kinda curious how the bumper removes in relationship to the 05..i would assume i just have to unplug the fog harness?
FYI...the CompTech instructions mention removing the "single bolt holding the factory air inlet to radiator support through the space in the chassis". This will be impossible unless you remove the bumper. I don't know if others that have installed IceBoxes without removing the bumper left this in place or what, but I had to remove the battery and battery cover to get to this bolt. Maybe I did it the hard way but I just couldn't find another way to do it.
Good Luck!!!
p.s. IceBox sounds pretty good. Exactly what I was looking for as far as sound. And, you can really hear that the car is breathing. I most like that the car does not have what I call "that cheap sound" when you take off from a dead stop. And the little roar around 3000 rpm's and up is also nice but not too noticable.
yeah, my friend had that problem....how long of a wrench do you suppose i need? I think we were using a 1 footer and still couldn't get it...
FYI, the liner under the front bumper can by lowered by removing a couple of clips. I did that and could actually get a good look at the area from underneath. I was able then to reach up from under to use a ratchet to loosen the bolt while looking thought the hole vacated by the foglight cover to see what I was doing.
Good info..
Actually, you might have better luck just undoing that bolt while the car is still stable on the ground. Then you can jack it up to remove the resonator.
is there something i have to peel back or remove from the bottom of the car if i want to get to the bitch-bolt? i haven't had time to check it yet and i'm trying to review some CAI or bumper-removal instructions to see what needs to be taken off. thanks!
cycdaniel
Dec 17, 2019 10:58 AM
Nitin
Sep 30, 2015 08:22 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
