05 auto high flow cat ?
Old May 18, 2007 | 12:23 PM
godfather2's Avatar
Time to Climb
i've been wanting the random tech high flow cat for some time now, but haven't because some of us have problems with CELs. if i understand correctly, the stock 06/07 catalytic converter has a higher flow than my oem piece. so, IS THE 06/07 CAT A DIRECT REPLACEMENT FOR MY CAR? if so, i'm buying it tomorrow!!!
thanks again everyone,
vinny
Old May 18, 2007 | 12:51 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Yep, direct replacement, although I don't know of anyone that has done it yet. Since the RT cat fits on the 06, then the 06 cat should fit on the 04/05 with no problems.
You can still get a RT Cat and have no CEL if you run with a defouler.
Old May 18, 2007 | 01:27 PM
Tsx536's Avatar
Rep'n Taxbrain.com
I'm thinking about dyno testing all 3 Cats, so you can wait for my results if you want to know the performance differences.
Old May 18, 2007 | 02:58 PM
JTso's Avatar
vinny
OEM cat is not cheap...
Old May 18, 2007 | 03:42 PM
rmpage's Avatar
Drives With Hands
Just get the RT cat and a $40 el cheapo scantool to clear the occasional DTC. Or run a pair of anti-foulers between the O2 sensor and the bung. I would be willing to bet the RT cat flows better than the 2006 MY OEM converter does anyway.
Old May 18, 2007 | 03:52 PM
Tsx536's Avatar
Rep'n Taxbrain.com
There's no doubt that the RT Cat will flow better than the 06 CAT. The big reason why I wanna test an 06 CAT is because I'm in Cali and they've been cracking down on SMOG legal parts in my area. If I lived in another state without all of the CARB rules, I would get the RT CAT, no questions asked.
Old May 18, 2007 | 04:17 PM
JTso's Avatar
What if you could buy a Metal cat for a little more than the RT cat?
Old May 18, 2007 | 04:39 PM
godfather2's Avatar
Time to Climb
i think i'd go for it ... what do you propose? another reason to go with 06 cat over rt - it should be quieter.
ANYONE WANNA GET RID OF THEIR CAT?
Old May 18, 2007 | 04:41 PM
godfather2's Avatar
Time to Climb
i'm fairly certain you're correct, but i don't want to have to fuss with all that. i've come to a point where i'm willing to spend a bit extra for peace of mind. you know what i mean? thanks for the input, however
Old May 18, 2007 | 05:36 PM
Excelerate's Avatar
Former Sponsor
http://strutking.com/tl-defouler.html
That is all you need. The RT is a bolt on unit. Thread that in first and then the 02 sensor and you will have no issues.
Old May 18, 2007 | 06:39 PM
godfather2's Avatar
Time to Climb
^ thanks, but i'm pretty sure some have reported CELs even with the defouler
Old May 19, 2007 | 09:39 AM
rmpage's Avatar
Drives With Hands
No problem dude, just offering my experience. The best mod is always the one that makes you happy.
Old May 19, 2007 | 10:25 AM
Reach's Avatar
godfather2, I had bigtime recurring CEL problems, but now i've been 8 months without a cel since I put a defouler on. It solved the issue.
Oh, and $13 is ridiculous, I got 2 of them for $3 at my advance auto parts store.
Old May 19, 2007 | 04:11 PM
godfather2's Avatar
Time to Climb
^ hmmm ...
Old May 21, 2007 | 09:18 PM
JTC05's Avatar
Can the stock cat be removed and hollowed out? I would guess also using the anti-fouler.
Old Jun 4, 2007 | 04:56 PM
godfather2's Avatar
Time to Climb
quick question - is the RT cat ceramic or metal?
Old Jun 4, 2007 | 05:31 PM
lcrazyaznl's Avatar
CL9 ABP
I just used a obII high flow cat from magnaflow.
no check engine lights but my sensor was dead after 60k miles
Old Jun 4, 2007 | 05:56 PM
Excelerate's Avatar
Former Sponsor
The RT cat for the TSX has a metallic substrate.
Old Jun 4, 2007 | 06:15 PM
godfather2's Avatar
Time to Climb
^ thanks excelerate, you're always on top of your game
Old Jun 4, 2007 | 08:32 PM
rmpage's Avatar
Drives With Hands
Yeah, but you'd be destroying a $900 part by doing so. Also a punched-out converter tends to be rough on the inside, increasing turbulence in the exhaust stream and subtracting from performance benefit. You would be much better off with a cheap Magnaflow welded up at a local muffler shop.
Old Jun 4, 2007 | 09:07 PM
chuson's Avatar
T.DoT P.I.M.P. lol
I'm still using your Mangaflow High-Flow cat rmpage.... it's holding up good. Thanks
Old Jun 4, 2007 | 10:53 PM
rmpage's Avatar
Drives With Hands
Glad to hear that! I should also add that the Magnaflow dyno'd the same as the Random Tech, at least on my car. There was a <1hp difference, which is within the margin of error of the dyno itself.
Old Jun 5, 2007 | 06:16 PM
CarbonGray Earl's Avatar
Does anyone know if the catalytic converters for the Honda Accord's k24's be compatible with our TSX? If so, would they be using the 400 cell cat when they went through a similar power upgrade in 06?
Would the same be true for the K24s used in the truck apps, like the CRV and Element?
Any parts experts know??
Old Jun 5, 2007 | 08:30 PM
godfather2's Avatar
Time to Climb
^ good question. i wasn't even aware the accord used a version of our engine
Old Jun 5, 2007 | 08:36 PM
Benz_05_TSX's Avatar
Why not just get the RT CAT? I don't have the CEL problem..
Old Jun 5, 2007 | 08:53 PM
godfather2's Avatar
Time to Climb
^ others do have a reoccuring CEL issue. most of which, can be corrected with an anti-fouler
Old Jun 5, 2007 | 09:08 PM
JTso's Avatar
According to the 04 4-cyl Accord test pipe on ebay (no longer available), the OAL is longer than the TSX, but the flanges should fit. This means the Accord cat is also longer than the TSX. Not sure about the actual cell numbers.
Old Jun 5, 2007 | 11:43 PM
Tsx6363's Avatar
ididn't know that accords ran on k24's...
Old Jun 6, 2007 | 12:39 AM
Thanks Jtso, appreciate it. It'd be interesting to know how much longer, since there is a little bit of play. But the cell count is going to be the most important to know.
Can't find anything so far in my own searches....
Old Jun 6, 2007 | 12:41 AM
Accords, CRV's, Elements....the CRV's had the K24 first, I believe. I believe the we have the highest output K24 though.
Old Jun 6, 2007 | 07:16 AM
Damned04's Avatar
That is the test pipe I had bought, fitment was perfect. I received a CEL after about 50 miles of driving before I had time to purchase antifoulers. I bolted two antifoulers on and the cel went away after a couple miles
Old Jun 7, 2007 | 01:41 AM
godfather2's Avatar
Time to Climb
couldn't find a decently priced 2006/07 oem cat, so i went ahead and purchased the rt cat for about $300+. i'b bidding on an 04 ecu as well, so wish me luck
NJALLDAY57
Oct 13, 2015 08:25 AM
Sep 17, 2015 10:16 AM
P1zzaman
Sep 16, 2015 06:46 PM
k6biv
Sep 10, 2015 06:37 PM
Mikehxbx
Aug 31, 2015 10:17 PM
