Will I fit - 6' 4" ???
I love everything I know about the TSX from reading articles, etc. I don't have a local dealer and would have to go about 100 miles to drive one. Question - is anyone out there 6' 4" tall? Will I fit comfortably into a TSX??
Thanks.
Thanks.
Someone stole "My Garage"
I'm 6'2 and have no problems -- I even have the seat forward about 1.5-2" from the rearmost setting and still have lots of room. Headroom is GREAT, too.
You might also take a look at these threads:
https://acurazine.com/forums/showthread.php?t=15728
https://acurazine.com/forums/showthread.php?t=26747
jlukja, who wishes he could find "that pic" of Dan Martin
Short enough
Or maybe I should say that the car is big enough?! From what I'm reading on the other threads it sounds like the TSX will be plenty big and comfortable enough for me.
Thanks for the help.
Earth-bound misfit
My husband is 6'3" - the first time he test drove with me he said it was maybe a little too small for him. Since I bought it, though, I seem to be having trouble reminding him that it's MY car! He has completely revised his opinion.
Let me help you!
OEM plus!
6'5" here, 34" inseam, and the room is pretty good. When you are this tall you kind of have to put up with things being a bit snug. I won't say there is a ton of head room but there is enough. You would have to recline the seat back past the b-pillar a little bit, but the telescoping steering wheel compensates for that well.
I sat in my friends Dodge Charger which is quite a bit larger and found that I have a bit more head clearance in my car. Maybe because his passenger seat doesn't have height adjustment though. You should be fine though, the only other way to get more headroom is to buy a car with no moonroof.
Here is a pic of how far the my seat is reclined. In the pic it looks like I have the gangsta lean going, but it is not as bad in person.
I'm 6'3. When I was looking for a car, this was a big issue for me aswell. I purchased an RSX and had to get the Canadian Stock trim with no moon roof in order for there to be enough headroom. I simply did not fit in any car comfortably with a moon roof. ANY CAR.
Then I needed a 4 door and was convinced the headroom wasnt going to be enough in the TSX, convinced so much that I never even tried. After a while I stumbled upon a friends TSX and low and behold, I fit perfectly. I bought one for myself and traded in the RSX. My hair still grazes the roof of the car from time to time but really no big deal. My father-in-laws accord does not give me enough headroom believe it or not. Non adjustable cloth seats though.
If you have short legs and a long torso, you might have headroom issues unless you recline the seat. If you're long legged, you won't have headroom problems but the legroom may strike you as inadequate. If you're in the middle -- or you don't care about reclining the seat -- and you have a 34" or so inseam, then you should be OK.
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
