where is coolant temp. needle suppose to be? mine is little below middle.
my coolant temp. needle is little below the middle, making it look a little cold. is this normal? or am i freaking out?
Let me help you!
That's normal. If the engine temperature is within a certain range, the gauge will go directly to that position. If it ever reaches center, then your car is running a little hotter than normal.
Should be somewhere around here:
https://acurazine.com/forums/showthr...ght=thermostat
I also was concerned because other cars have it land exactly at the middle.
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
