VSA question
Old Dec 4, 2005 | 01:31 PM
avenutolo's Avatar
VSA question
I have an 05 TSX and I have a VSA question. When the VSA is on (the default) only my exclaimation point goes on (!) and not "VSA"
When you're in the rain or snow, how do I know it's working? What shows on the dash?
Only asking since because yesterday my VSA got all confused and I had to reset it (basically just restarting the engine). Both lights went on -- the exclamation and the VSA. PLUS ... the seat belt chime stopped!!
Has this happened to anyone else?
Thanks!
Old Dec 4, 2005 | 01:40 PM
moda_way's Avatar
No... whenever VSA is active, you shouldn't have any light. When you disarm it, the triangle and exclamation point show up.
Old Dec 4, 2005 | 02:15 PM
avenutolo's Avatar
yes but ... when it's working the ! point comes on when it gets activated
Old Dec 4, 2005 | 02:37 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
When VSA is working the /!\ will flash.
Old Dec 4, 2005 | 02:56 PM
feliz's Avatar
Yup, that's how mine works.
Old Dec 4, 2005 | 04:33 PM
avenutolo's Avatar
Does it say VSA /!\ or just /!\
Old Dec 4, 2005 | 04:36 PM
phirenze's Avatar
The extra b is for byobb
Just /!\.
If you see the "VSA" light illuminated while driving that means the system has malfunctioned. Just like the "ABS" light coming on.
Old Dec 4, 2005 | 05:55 PM
Encyclo's Avatar
Have not played in the snow and ice a lot yet (and probably will not if I can manage it ). I went to try to activate the VSA on a patch of ice yesterday; when I braked, the ABS pulsated as expected. When I started in 1st (6 Spd) the VSA illumivated, with slight pulsating and...electronic beeping .
Is it normal to get a beep when the VSA engages?
Old Dec 4, 2005 | 06:33 PM
curls's Avatar
Someone stole "My Garage"
I don't think so but I might be wrong. I get a beeping when I leave the parking brake on (or use it for the all-famous snow-turns! )
Old Dec 4, 2005 | 07:22 PM
Encyclo's Avatar
Thanks Curls ,
Now that you mention it, I was holding the handbrake to help the front wheels spin to trigger the VSA. .
That probably explains it
Old Dec 5, 2005 | 12:23 AM
grasseater's Avatar
I live in Omaha and with the 6+ inches we got this last week I've had my VSA kick in numerous times and there's no beeping involved. I would def call the dealer about that. And like someone above said, if you're getting the actual VSA light in addition to/instead of the /!\ you have a problem with the system.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
juanrl
Sep 29, 2015 03:25 AM
navtool.com
Sep 25, 2015 05:15 PM
