Please help, gf bought car with kit...
my girlfriend just bought a tsx with the factory kit. last wk, we took it out of town and we notice very loud noise coming from the side skirt. my question is, does the dealer use double sided tape and screw when they install it? or is this noise normal. the car is in the dealer right now and they said they can not fix the problem. any suggestions?
thanks.
thanks.
easy fix
bought a art supply foam pad from walmart for 50cents
and went to my bodyshop to glue those pad on 8 different points
they did it for free cuz i was fixing some other stuff...
I begin to think all Acura dealerships are retarded
thanks.
thanks.
I guess you can push on it throughout the length of the skirt.... sometimes they didn't push it in all the way and some of the plastic clips dont' click.... if you push it in and hear a 'click' then that's probably it...
The other thing I can think of is that they didn't install those little black foam washers that goes around those plastic clicks, causing the skirt to hit against the body, or perhaps the plastic piece that goes in the front of the skirt at the front wheel well.
in short, just take it back to the dealer
thanks.
thanks.
we did bring it back to the dealer. the master tech said he couldn't duplicate the noise so he couldn't fix it.
easy fix
here "other forum"/forums/showthread.php?t=8123
anyway....i posted solution on 3rd post
rattle is indeed pretty loud
but you need to go pass 50 to hear it
Just FYI, on the factory kit (for the '05), only the front and rear pieces had tape. You can get similar 3M tape at W*Mart if you need to. The side skirts, they just have locking tabs that are hard to describe. You might go to one of the online sites that sell OEM parts and download the instructions just so you can see how it works/fits.
I wonder if they missed something in the install. Like someone else said, maybe they didn't get one or more pegs clicked into place. I'd hate to try to fix it myself, though, since it should be their problem to fix. If you try fixing it yourself and then break it, then they definitely won't fix it for you (but charge more!).
Maybe find a better dealer? Good luck....
handsom-hustla
Nov 13, 2015 05:04 PM
nanos
Nov 12, 2015 08:41 PM
you paid for it remember ?
