VSA noise
VSA noise
My house is on top of a hill and today when i pulled up the driveway, i had some trouble making it to the top. I noticed the VSA kick in and the light come on but then a weird noise, like a grinding noise started. This may or may not be normal. Any thoughts or similiar issues?
Yes, everything's normal, the VSA does make that crunch-crunch sound.
It's tell-tale that you're using your car to it's full extent.
I had a whole lot of "crunch-crunch" myself when I did this: https://acurazine.com/forums/showthread.php?t=16454
Originally Posted by RMATIC09
Yea, that noise is normal when vsa comes on, i think its the ABS being applied.
and yep, it's a low growling sound, doesn't last long, emerges when I'm engaged in some tight handling or swift controlled braking (as opposed to uncontrolled braking? but you know what I mean). At first I was freaked, but now I view it as neat.
Originally Posted by xizor
well the vsa was probably applying the brakes, maybe ABS was the grinding noise you thought u heard?
To me this is either the traction control aspect of VSA kicking on because something caused the uphill driveway climb to be very slick ... or something is wrong with the car.
Maybe the sound was the ABS pulsing the brakes to reduce wheel spin. This is assuming their was initial wheel spin when pulling up the drive way.
Originally Posted by Acura Website
The traction control component of VSAŽ uses sensors that monitor the front wheels and computer-controlled modulation of engine power and front brakes to help prevent wheel spin when starting out or accelerating. If the sensors detect excessive front-wheel spin during acceleration, the traction control function automatically closes a secondary throttle valve until wheel spin stops. This helps the TSX maintain traction during acceleration and helps the driver retain steering control, even when accelerating on slippery surfaces.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
