TSX & RSX gages: does the 6 o'clock positons affect your driving?
My apologies if this was a past thread.
I'm sure most of you have noticed that the gage styling of the RSX and TSX have the RPM and speedometer needles oriented in an unconventional fashion:
Typically, the '0' positions of both are around the 8 o'clock portions of the dials. Does anyone know if there was a functional purpose of the RSX / TSX design? The reason I ask is because I've noticed that the gages "dare" me to rev the motor and go faster.
I didn't notice the mental effect it has on my driving until I test drove an older Civic coupe and Acura RL. When I hit 3000 RPM on either of them, the needle give the impression of a much busier engine, almost as if it were a hint for you to back off.
Gages!? We ain't got no gages. We don't need no gages! I don't have to show you any stinking gages.
Originally Posted by ILoveMyHonda
But in all seriousness, when i first started driving it, yes i had to reorientate myself to the difference.
Or else i'd be shifting at 5k all the time
or worse, you'd be driving 80 mph most of the time
Originally Posted by 04EuroAccordTsx
It's spelled "gauges"
http://dictionary.reference.com/browse/gauges
It took me a little while to get used to the speedometer in that orientation. It just looks so pathetic when you're driving 30 MPH and looks like a wet noodle (if you catch my drift)...and then I realize I'm in the parking lot.
The eye can catch the 12 o'clock of the tach without really needing to have you look at the numbers; you know that when it gets to vertical you shift unless you need to push it.
On the speedo, that 12 o'clock position looks just about right, too!
The first drive in my new TSX back in 2005 was coming straight from my G2 Integra (with the typical 8:00 is '0' gauges). I drove the G2 to the dealer to pick up my TSX at lunch... hopped in, and on the freeway back to work, I was so happy/giddy that I was probably leadfooting a bit, but also thrown off by the orientation of the gauges and soon realized that no, traffic wasn't slow that day, I was doing 160 km/h on a downtown freeway (normally 100 km/h speed limit). Needless to say, the brakes work well.
How does the position of the numbers affect anything? They could have made the ticks spread out more and adjust the needle to compensate. It's just visual, and it has no bearing on your other senses. I listen to the engine to tell me when it's time to shift. I look at the gauge for a split second and I know what the speed and rpm is. I know how the car behaves, so if I saw the needle at 5.8k rpm, then I know it's about to jump to 7k with vtec. Heck, I can feel the bumps in the road and see all the landmarks fly by, and that tells me if I'm going too fast or not.
Maybe it's the color...blue/white makes you think you're more energized and ready for more action? *shrugs*
Also you tend to use your peripheral vision to 'read' the speedo and tach (I know I do), and if its accustomed to a 'regular' setup (8:00 = 0rpm / 0kmh), and you throw a zero-degree gauges cluster at it, it can and does screw things up until you adjust.
As I said, once I LOOKED down, and read the numbers, I realized "oh shit!" and slowed down... but relying on positioning of a needle w/o looking at the nubmers, from a different perspective, was fun at the start.
Originally Posted by BoxedUp
cycdaniel
12-17-2019 10:58 AM
divac
08-29-2018 10:13 AM
brandnewcolony
09-12-2015 10:39 AM
