Trunk button
Old Jul 10, 2013 | 06:29 AM
fujiteam's Avatar
Trunk button
I have discovered that the button on my trunk does not work. The release inside the car works. The button on the key fob works. I double checked that I had unlocked all teh doors and still nothing.
Is this a fuse issue or something else?
Old Jul 10, 2013 | 06:31 AM
i know in the TL there is a trunk release valet button thing in the glove compartment.
see if its there in the TSX!
Old Jul 10, 2013 | 10:57 AM
Mskierki's Avatar
All the doors need to be unlocked before you can use the button on the trunk.
Old Jul 10, 2013 | 02:09 PM
fujiteam's Avatar
I did that. Even opened one door (rear driver) and shut it to make sure I had not re-locked.
Old Jul 10, 2013 | 08:51 PM
Davu's Avatar
yeah, there's a trunk switch unlock thing in the glove compartment. top left inside
Old Jul 11, 2013 | 12:17 AM
csmaan12's Avatar
POWER!!
I had a similar thing happen. Not sure what caused it but, after I reset the battery for 30 min it fixed itself. I literally have no clue what it was, the fuses were all good too.
Old Jul 11, 2013 | 01:03 PM
street277's Avatar
Yep! good chance it's the valet switch!
Old Jul 15, 2013 | 06:21 AM
fujiteam's Avatar
It was the valet switch. I had no idea it existed. Must have hit it with something int he glvoe box.
Old Jul 21, 2013 | 06:53 PM
redpoint's Avatar
Good to hear this was an easy fix.
FYI- Trunk release button on the fob works even when the car is locked.
Old Jul 30, 2014 | 04:08 PM
jkcutter's Avatar
7th Gear
Hello,
I'm glad the original poster solved his problem with the valet switch. For others who might have a problem with their trunk release...
My 2005 TL's trunk release became intermittent. When I pressed either the dash button or the key fob button, the release made no sound. I suspected an electrical problem.
After ensuring that valet switch in the glove compartment was ON, the owner of an electrical shop advised me to lubricate the release mechanism before doing any electrical troubleshooting. I didn’t think that would work, because there was no indication that there was any power to the release; but I tried lubrication anyway.
I filled all the cavities of the release with white lithium grease, and worked the mechanism back and forth many times.
To my surprise, that solved the problem. Now, the trunk opens every time.
Good luck!
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
hashbrown
Sep 29, 2015 12:13 PM
dirleton
Sep 29, 2015 08:26 AM
thegipper
Sep 28, 2015 01:01 PM
