TOV 2006 TSX driving impression
Old Mar 29, 2006 | 10:57 AM
Yui's Avatar
Yui
http://www.vtec.net/articles/view-ar...icle_id=493583
Old Mar 29, 2006 | 11:21 AM
dom's Avatar
dom
The new for '06 10-spoke wheels are nice enough, but we're partial to the original 7-spokers found on '04 and '05 models - they just seem more appropriate for the lines of the car.
:ibSTLemailsTOVbitchingandcomplaining:
So about 10HP more. Nice 0-60 and 1/4 mile times. Even for the AT.
Old Mar 29, 2006 | 11:22 AM
Tintin's Avatar
fun read.
cant wait to own a TSX!
Old Mar 29, 2006 | 11:30 AM
jlukja's Avatar
finally some reliable 0-60 and 1/4-mile times for the AT.
Old Mar 29, 2006 | 11:35 AM
jlukja's Avatar
One item that has escaped Acura's attention is the TSX's brakes. We're going to be brutally honest: the stock brake pads are pretty bad. The feel is okay, but they provide somewhat weak stopping power and are prone to overheating easily (particularly when slowing from freeway speeds). When they overheat, they tend to leave deposits on the rotors, which can lead to a very noticeable and irritating brake shudder. Many people misdiagnose this problem as rotor warpage, but as we proved on our own car, it's really the stock pads chubbing the rotors. It only took a few thousand miles for this problem to appear on our TSX project car, and these were very gentle miles. While the symptoms felt almost exactly like rotor warpage, we decided to swap out the stock pads for some more aggressive aftermarket pads, and the results were simply astounding. Without any rotor resurfacing, the brake shudder and wobble disappeared almost immediately, and within a few days of normal driving, all of the OEM pad deposits were wiped clean from the rotors. To this day, there has been absolutely no brake shudder and brake fade is a thing of the past. Even more impressively, the car has benefitted from a tremendous improvement in braking power. The only downside to this pad upgrade is that the new pads will squeak in very rare circumstances and they generate appreciably more brake dust than the stock pads. Otherwise they are one of the biggest "bang for the buck" modifications out there for the TSX and we highly recommend it. We installed Axxis Ultimates on our TSX, but similar results are likely with any number of other aftermarket fitments.
And maybe a conclusive report on all the "warped" rotor reports we've seen posted. Interesting.
Old Mar 29, 2006 | 11:48 AM
dom's Avatar
dom
I'm scared to ask but if an 06 gets to 60 in 7.7, then what does and 04/05 do?
Old Mar 29, 2006 | 12:00 PM
jlukja's Avatar
Icebox+Hondata
Old Mar 29, 2006 | 12:06 PM
GIBSON6594's Avatar
My Garage
Can we sticky this quote?
"Of course, we've asked what the actual difference is and Acura claims that the revised motor would have been rated at 210hp using the older SAE method, so this motor should be about 10hp stronger than last year's."
Old Mar 29, 2006 | 12:12 PM
GIBSON6594's Avatar
My Garage
Don't forget this:
"The new for '06 9-spoke wheels are nice enough, but we're partial to the original 7-spokers found on '04 and '05 models - they just seem more appropriate for the lines of the car."
Old Mar 29, 2006 | 12:51 PM
dom's Avatar
dom
So are they 9 or 10 spokes? I could never stare at them long enough to tell.
Old Mar 29, 2006 | 01:23 PM
Beoshingus's Avatar
Overlord
Good article. I'll forward that to my dad, who likes my car so much he's thinking of getting one for himself...
Old Mar 29, 2006 | 06:28 PM
STL's Avatar
STL
dyno comparo
The '06 gains look pretty impressive to me (over 17HP and 14 ft-lbs at 6400rpm) -- and the '04 motor was more broken in too!!
Old Mar 29, 2006 | 07:10 PM
curls's Avatar
Someone stole "My Garage"
9. TOV can't count.
Or they had the same "problem" as you did. LOL.
Old Mar 29, 2006 | 09:15 PM
waTSX's Avatar
Have camera, will travel
Jeff over at ToV does a nice job. A real enthusiast and big fan of the TSX, too.
Old Mar 29, 2006 | 09:58 PM
psteng19's Avatar
Originally Posted by STL
dyno comparo
Can't wait to hit VTEC... still in break-in.
Old Mar 29, 2006 | 10:05 PM
CGTSX2004's Avatar
It's nice to see a lot of our opinions and thoughts on the TSX validated.
And I can speak from personal experience that the Axxis Ultimates made a tremendous difference in braking performance. Once the brakes on my 06 wear to the point of replacement, I will likely buy another set to put on.
As for the 0-60 times, I certainly hope that shuts up a few of those people complaining about how not quick the TSX is.
Finally, it's 9 spokes, . You're attention span is slipping in your old age, isn't it?
Old Mar 29, 2006 | 10:24 PM
mg7726's Avatar
She said: it's GINORMOUS!
good read.
glad i got rid of the brakes and tires, there is much more enjoyment outta the aftermarkets
Old Mar 30, 2006 | 08:13 AM
dom's Avatar
dom
I just had lunch.
jriv7
May 8, 2020 05:50 PM
Feb 25, 2020 09:57 AM
divac
Aug 29, 2018 10:13 AM
PortlandRL
Sep 14, 2015 12:01 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
