Stop HIDs from flashing when locking door
I read the manual, and it says with the Door Lock Acknowledge on, the car will beep and flash external lights if you press the lock button twice. At night, if I leave my HIDs on, it flashes the HIDs too. Of course, I don't want it to do that because it's not good for the HIDs. I could just turn off my nights but I like how they light up when I unlock the door. Very bright and cool. Any ideas on how to have the best of both worlds?? Also, just to make sure, the first press on the lock button locks all the door AND turn on security. The second press is just to confirm the security is set. Right?
HID = High Intensity Discharge
It's a term used to describe what are typically xenon gas filled bulbs that are bright enough to light up close to near daylight conditions.
And to answer ninjamyst's question, no, there is no way. However, since you have an 06, just go into your MID settings and change the settings for the lights to something other than the standard 15 seconds.
Originally Posted by Red_TSX
thanks and what MID wow i am such a
Originally Posted by ninjamyst
maybe I didn't explain clearly. I want the HIDs to stay on for 15secs or whatever when I leave my car. However, what I don't want is for the HIDs to flash when I press the lock button twice on the key fob. I am only worried about flashing the HIDs too much but I guess if it's built-into the car, it shouldn't be too bad right?
As the system is set up now, there is not way to do it. I think it would take some tampering with the security system and that's not an area most people want to mess around with.
Then just stick around the 15 seconds, wait for the lights to go off, and then lock your car.
Oh I agree with you Ninjamyst. I don't like the fact that the lights flash off/on like that again....it's kinda silly - and probably not too good for the light....and I definitely agree with you how cool it looks with the lights on like that at night when you unlock the door.
I wish Acura would have just included that little "beep" with the one push instead of having to push the remote twice to "confirm". Maybe they'll do away with that feature in their next round.
Originally Posted by fuckleberry
seems you're nuts about the TSX, have you even looked at http://www.acura.com/index.aspx?initPath=TSX ?
The only way around it is to lock your doors with the power lock switch, or the drivers door lock knob and then close the drivres door. The doors will lock, the alarm will arm, and there will be no blinking of the outside lights.
do they? I thought one press just locks the doors with no indication at all.....too bad i dont have my tsx with me right now.
Originally Posted by driver centric
On my 06 it does. If I press the lock button once, it just flashes the parking lights. If I press it twice, it flashes the parking lights (twice) and the piezo buzzer sounds on the second press.
The HID's don't flash at all, just the parking lights (2006 model year).
Originally Posted by psteng19
Same here.
I think the OP is wondering if you can do this without having the headlights turn off and back on like that; rapid on/off operation isn't good for HID lights.
MID = multi-information display
You have an 04. It didn't come equipped with the MID.
Originally Posted by Dan Martin
Or you could just press lock once.
I will just turn my lights off then. I just thought this was a common issue but I guess no one really worry about the HIDs flashing. Thanks
Same here.
Like LSIII said, use the power door lock switch on the driver's armrest before you close the door. This will enable you to lock the car, arm the security system, and prevent the HIDs from flashing.
thats so weird
down under in aus, our euros would beep + the indicators will all flash three times when i press the lock button once
and when i turn it on, the inidcators come one once but a tad longer than a second
i guess different places have different features incorporated into em
i read this a while back but u guys dont have automatic locking of the doors once you start moving ey?
ours lock the moment we step on the brakes when we either change it from park to drive or when we brake to slow down
Originally Posted by Lao Sticky Rice
thats so weird
. I want DRL!! And that auto lock sounds good too as a safety feature.
This may not answer you question but my
Even though this auto-on/off headlight feature is incorporated into the vehicle, I advise against using it.
I may be wrong, but only because when a vehicle is initially started and later also when shut off, a small voltage spike occurs from the alternator, thus causing possible long term damage to the balasts and or other lights in the car.
My basic rule that I alwaus used....Car on, Lights on. Lights off, Car off.
As always, US gets screwed on cool features
. I want DRL!! And that auto lock sounds good too as a safety feature.As for the auto lock, it sounds better than kptechnologies module. Thank goodness my university forced me to learn electronics...I'll just build my own module to duplicate the aus auto-lock hehe...it'll work for MT's I believe...yay
. I want DRL!! And that auto lock sounds good too as a safety feature.I sooooo do not understand why Honda deactivates this in their US cars !!!!!
Originally Posted by DLTSX6MT
I want the "low windshield wiper fluid" alert that the Canadians get!
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
peregrine22
ILX Audio, Bluetooth, Electronics & Navigation
Jan 12, 2017 10:32 AM
