problems with headlights on buddys 04 tsx
i have a homie thats been havin problems with his lights and interior lights...his headlights flicker from time to time he lost his stock alarm remote and held the key for 5 secs like dealer told him to...didnt work then he removed what he thought was the fuse for the alarm turned out to be the wrong fuse and had a check engine light..a few days ago the cel turned off and his headlights started flickering all this from the alarm???can anyone help diagnose thanks
His headlights AND his interior lights are flickering? You seem to emphasize on his headlights, so which is it? Did you figure out what fuse you guys ended up pulling and did you guys put it back?
Lol ^^^dick....he doesn't know what fuse was pulled....was having problems with him interior lights and dash lights but now his headlights flicker hes stuck on the problem..he took the car to the dealership and they couldn't find the problem either I thought I'd see if I can get and feedback and see if maybe someone has had that dame problem and if they got it fixed
A blown fuse would typically not result in an intermittent issue.
If the dealer couldn't find anything the fuses are probably all in place and intact. It might just be a bad ground which would be difficult to find without some knowledge of electronics.
Also if the punctuation above was giving you trouble I have translated it for you:
there is nothing that canz be done at this point blown fuse would typically not result in an intermittent issue if the dealer cant find anything.. just be best to take the car to the dezert and light it on fyre
cycdaniel
12-17-2019 10:58 AM
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
