outer door sticker
Advanced.
Originally Posted by parag_a2z
Actually, wat are door stickers...i am clueless....
blacktsx05, have you checked with your local dealer on getting these?
They are not very easy to replace. First you have to get ALL the old decal and ALL the adhesive off the door frame without scratching the painted finish underneath. If you get even the slightest imperfection in the suface underneath it will REALLY show up through the black decal. Use a very weak detergent/water solution sprayed on the decal and the door frame to allow you to position the decal and help get air bubbles out, then squeegee it down. I'd suggest taking it to a good body shop for install, as most know how to do it right. It's really easy to have it look worse than it did before if you don't do it right.
^^^There isn't a tint removal solution. Well.....a razor blade is the tint removal solution. You might try using a heat gun. Just don't burn your gaskets. That's what you use to remove vinyl graphics. Heat it up and peel a little bit at a time. Then heat and peel,.etc. Then use rubbing alcohol to remove any excess glue.
soupi
14
11-15-2015 11:15 AM
