Need Help with Navigation System TSX
My navigation is in Kanji (Japanese) can anyone just send instructions to setup clock so atleast i can set the time.
There are two clocks in the car
1. In the Dash
2. In navigation system
1. In the Dash
The clocks are the same. When you change the navi's time, the dashboard changes. If it's set to use the gps time for your clock, then it should have the correct time. However, with the new daylight saving time rule, someone probably turned it off.
I don't know if your menu layout is the same. Don't we have an international forum? Maybe post some screen shots, and someone there can translate
cycdaniel
Dec 17, 2019 10:58 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Gianni Formica
Sep 7, 2015 08:28 PM
