immobiizer?
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
Can someone tell me exactly what this is and if i wanted to do an ecu swap would i have to get this "immobilizer" from the same car i got the ecu from?
Sorry for my lack of knowledge. Im confused...it seems so technical..haha
To start, welcome. Next, wrong section to post in. Finally a search would help you here.
The immobilizer chip in the key and its recognition by the ECU are a match you can not break if you intend to start the car. If the ECU recognize the chip in the key, the car doesn't stop. That's all its about.
Originally Posted by aaronng
You need 3 parts from the donor car. You need the ECU, Key(s) and the immobilizer ring (located at the ignition barrel)
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
You would need 3 "code matching" components to start the engine. If you are swapping ECU from another car, you have a few options.
Option 1::
1. Get the ECU, matching immobilizer, and key(s) from the same car.
2. Remove the transponder chip from the keys(s).
3. Transplant the transponder chips into an Accord keyfob (the easiest method). Check with moda_way with the transplant operation. The actual key part is no good and it won't fit the door lock or ignition cylinder.
Option 2:
1. Get the ECU (other matching components not available).
2. Drive to the dealer with the ECU.
3. Ask the dealer to install the ECU and code match your other existing components (immobilizer and keys).
Option 3::
2. Buy a new immobilizer from the dealer.
3. Ask the dealer to install and code match all three components (ECU, immobilizer and one of your existing keys). Optionally, you can buy a new key and keep the original keys.
4. Keep the original ECU, immobilizer and key so you can easily return back to stock if necessary and sell the complete Hondata reflash package (I prefer this method).
Option 1::
Option 2:
Option 3::
Driver/Detailer
Originally Posted by moda_way
I believe all TSX immobilizer rings are the same... aren't they just picking up the response from the immobilizer chip? ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
The rings are different, unless you want to reprogram them at the dealers.
odindali
07-12-2023 05:00 AM
screaminz28
03-24-2017 08:19 AM
