New Technical Service Bulletins/NHTSA
Old Jan 26, 2002 | 12:56 PM
NOVAwhiteTypeS's Avatar
http://www.nhtsa.dot.gov/cars/problems/tsb/central2.cfm
Looks liek the list kinda grew from when I saw last.
Make: ACURA Model: 3.2CL Year: 2001
Service Bulletin Number: 00032 Bulletin Sequence Number: 155 Date of Bulletin: 11/00
NHTSA Item Number: SB615579
Component: STRUCTURE:BODY ROOF
Summary:
ON ALL 1999-01 3.2TL, 2001 3.2CL AND 2001 MDX MODEL VEHICLES, THE MOONROOF SEAL SQUEAKS AGAINST THE ROOF WHEN THE GLASS IS CLOSED AND THE SUNSHADE IS OPEN. *TT
Service Bulletin Number: 00033 Bulletin Sequence Number: 155 Date of Bulletin: 11/00
NHTSA Item Number: SB615580
Component: INTERIOR SYSTEMS:PASSIVE RESTRAINTS
Summary:
SOME 2000 3.2TL AND 2001 3.2CL MODEL VEHICLES MAY EXHIBIT THE SRS LIGHT ON WITH DIAGNOSTIC TROUBLE CODE 15-1 (FAULTY OCCUPANT POSITION DETECTION SYSTEM UNIT) STORED. *TT
Service Bulletin Number: 01001 Bulletin Sequence Number: 176 Date of Bulletin: 01/01
NHTSA Item Number: SB617703
Component: ENGINE
Summary:
SOME VEHICLES WITHIN CERTAIN VIN RANGES MAY EXHIBIT EXCESSIVE CRANKING TO START THE ENGINE AFTER THE VEHICLE IS DRIVEN AND THEN PARKED (WITH THE ENGINE OFF) FOR ABOUT 15 TO 20 MINUTES. *TT
Service Bulletin Number: 010101 Bulletin Sequence Number: 176 Date of Bulletin: 01/01
NHTSA Item Number: SB617690
Component: ENGINE
Summary:
TECH LINE SUMMARY REGARDING AIR CLEANER SEVERE CONDITIONS MAINTENANCE SCHEDULE. *TT
NHTSA Item Number: SB617694
Component: TRACTION CONTROL SYSTEM
Summary:
TECH LINE SUMMARY REGARDING THE TRACTION CONTROL SYSTEM. *TT
NHTSA Item Number: SB617695
Component: VISUAL SYSTEMS:WINDSHIELD WIPER
Summary:
TECH LINE SUMMARY REGARDING THE INTERMITTENT WIPER FEATURE. *TT
NHTSA Item Number: SB617697
Component: INTERIOR SYSTEMS:ACTIVE SEAT AND SHOULDER BELTS AND BELT ANCHOR
Summary:
INFORMATION ON REPLACING SEAT BELT TENSIONERS AFTER DEPLOYMENT. *TT
Service Bulletin Number: 01011 Bulletin Sequence Number: 187 Date of Bulletin: 02/01
NHTSA Item Number: SB618754
Component: ENGINE COOLING SYSTEM:FAN
Summary:
ON SOME VEHICLES, THE RADIATOR FAN AND / OR THE CONDENSER FAN RUNS CONTINUOUSLY; OR, IF THE FAN(S) RAN CONTINUOUSLY WHEN THE ENGINE WAS OFF, THE BATTERY MAY BE DISCHARGED. *TT
Service Bulletin Number: 01013 Bulletin Sequence Number: 198 Date of Bulletin: 03/01
NHTSA Item Number: SB619881
Component: INTERIOR SYSTEMS:PASSIVE RESTRAINT:AIR BAG IMPACT SENSOR
Summary:
A CONDITION MAY EXIST WHERE THE SRS INDICATOR IS ON AND DIAGNOSTIC TROUBLE CODE 15-3 (FAULTY OPDS SENSOR) IS SET. *TT
Service Bulletin Number: 01016 Bulletin Sequence Number: 626 Date of Bulletin: 09/01
NHTSA Item Number: SB626144
Component: INTERIOR SYSTEMS:INSTRUMENT PANEL:GAUGE:INDICATOR
Summary:
SUBJECT PERTAINING TO MALFUNCTION INDICATOR LAMP COMES WITH DIAGNOSTIC TROUBLE CODE P0128 OR P1486. *JB
Service Bulletin Number: 01017 Bulletin Sequence Number: 626 Date of Bulletin: 10/01
NHTSA Item Number: SB626239
Component: BRAKES:HYDRAULICISC:PADS AND SHOES
Summary:
VEHICLES MAY EXPERIENCE BRAKE PEDAL PULSE. *JB
Service Bulletin Number: 010200 Bulletin Sequence Number: 187 Date of Bulletin: 02/00
NHTSA Item Number: SB618757
Component: ENGINE COOLING SYSTEMTHER PARTS
Summary:
BRIEF INFORMATION ON TROUBLESHOOTING THE ENGINE COOLANT TEMPERATURE (ECT) SENSOR. *TT
Service Bulletin Number: 010201 Bulletin Sequence Number: 198 Date of Bulletin: 02/01
NHTSA Item Number: SB619886
Summary:
SUBJECT REGARDING CURRENT VARIABLE INTERMITTENT WIPERS SPEED SENSITIVE. *TT
NHTSA Item Number: SB619888
Summary:
INFORMATION ON TROUBLESHOOTING DIAGNOSTIC TROUBLE CODE P0138. *TT
Service Bulletin Number: 010301 Bulletin Sequence Number: 198 Date of Bulletin: 03/01
NHTSA Item Number: SB619896
Summary:
SUBJECT REGARDING TRACTION CONTROL SYSTEM (TCS) OPERATION. *TT
NHTSA Item Number: SB619900
Component: POWER TRAIN:CLUTCH ASSEMBLYTHER PARTS
Summary:
SUBJECT REGARDING AUTOMATIC TRANSAXLE CLUTCH PRESSURE SWITCH. *TT
NHTSA Item Number: SB619906
Component: STEERING
Summary:
INFORMATION ON VEHICLE STABILITY ASSIST ACTIVATING TOO SOON. *TT
Service Bulletin Number: 01031 Bulletin Sequence Number: 626 Date of Bulletin: 09/01
NHTSA Item Number: SB626151
Component: LIGHTING:LAMP OR SOCKET:UNSPECIFIED LIGHT
Summary:
VEHICLES MAY EXPERIENCE BURNED OUT ROAD LAMP BULB. *JB
Service Bulletin Number: 01041 Bulletin Sequence Number: 626 Date of Bulletin: 10/01
NHTSA Item Number: SB626267
Component: ENGINE
Summary:
INFORMATION ON V6 ENGINE OIL LEAKS.*JB
Service Bulletin Number: 01072001 Bulletin Sequence Number: 623 Date of Bulletin: 08/01
NHTSA Item Number: SB623461
Summary:
SUBJECT REGARDING SRS DIAGNOSTIC TROUBLE CODE.*YD 8UC 15-3 SET BY ELECTRONIC INTERFERENCE. *YD
Service Bulletin Number: 011000 Bulletin Sequence Number: 187 Date of Bulletin: 10/00
NHTSA Item Number: SB618765
Component: BRAKES:HYDRAULIC SYSTEM
Summary:
INFORMATION USING THE CORRECT BRAKE FOR IMMOBI CODE ON VARIOUS MODELS. INFORMATION USING THE CORRECT BRAKE FOR IMMOBI CODE ON VARIOUS MODELS. INFORMATION USING THE CORRECT BRAKE FOR IMMOBI CODE ON VARIOUS MODELS INCLUDING INFORMATION USING THE CORRECT BRAKE FOR IMMOBI CODE ON VARIOUS MODELS INCLUDING *TT 2.3CL. *TT 2.3CL. *TT *TT
NHTSA Item Number: SB618766
Component: ENGINE AND ENGINE COOLING SYSTEM
Summary:
ON SOME VEHICLES, FAULTY FRONT AND REAR WATER PASSAGE GASKETS AT THE FRONT CYLINDER HEAD CAN CAUSE A COOLANT LEAK NEXT TO THE EGR VALVE. *TT
NHTSA Item Number: SB618768
Component: ELECTRICAL SYSTEM
Summary:
SUBJECT REGARDING ETM FIX - KEYLESS RECEIVER LOCATION. *TT
Service Bulletin Number: 1001 Bulletin Sequence Number: 626 Date of Bulletin: 10/01
NHTSA Item Number: SB626590
Component: POWER TRAIN:TRANSMISSION:UNKNOWN TYPE
Summary:
SUBJECT REGARDING SPEED SENSOR PLUG MISSING. *YD
Service Bulletin Number: 160301 Bulletin Sequence Number: 198 Date of Bulletin: 03/01
NHTSA Item Number: SB619902
Component: ENGINETHER PARTS
Summary:
INFORMATION ON VEHICLES EXHIBITING DIAGNOSTIC TROUBLE CODE P1486 AND / OR P0128 THERMOSTAT PERFORMANCE. *TT
Service Bulletin Number: 701 Bulletin Sequence Number: 626 Date of Bulletin: 07/01
NHTSA Item Number: SB626550
Component: VISUAL SYSTEMS:GLASS
Summary:
SUBJECT REGARDING WITH NAVIGATION SKYSTEM - REAR WINDOW TINT APPLICATION TIPS. *YD
Service Bulletin Number: 901 Bulletin Sequence Number: 626 Date of Bulletin: 09/01
NHTSA Item Number: SB626530
Summary:
SUBJECT REGARDING SRS LIGHT ON AFTER OPDS CONTROL UNIT REPLACEMENT. *YD
Old Jan 26, 2002 | 12:59 PM
For me
#626-VEHICLES MAY EXPERIENCE BURNED OUT ROAD LAMP BULB. *JB
#176-SOME VEHICLES WITHIN CERTAIN VIN RANGES MAY EXHIBIT EXCESSIVE CRANKING TO START THE ENGINE AFTER THE VEHICLE IS DRIVEN AND THEN PARKED (WITH THE ENGINE OFF) FOR ABOUT 15 TO 20 MINUTES. *TT
#155-ON ALL 1999-01 3.2TL, 2001 3.2CL AND 2001 MDX MODEL VEHICLES, THE MOONROOF SEAL SQUEAKS AGAINST THE ROOF WHEN THE GLASS IS CLOSED AND THE SUNSHADE IS OPEN.
#626-SUBJECT REGARDING WITH NAVIGATION SKYSTEM - REAR WINDOW TINT APPLICATION TIPS. *YD
Old Jan 26, 2002 | 01:00 PM
BakedWafer's Avatar
Grand Turismo
yeah
It's friggin long now. Acura Sucks. PLEASE FIX my seatbelts!
Old Jan 26, 2002 | 02:20 PM
Rescuer's Avatar
Evil Bob Knieval
my car is at the dealership right now getting a new tranny (i get it back on monday) and i'm gonna print this stuff out, and have them fix a few things.
well just the moon roof sqeeking, and the seatbelt tensioner
somebody should sticky this thread :P
Old Jan 26, 2002 | 06:37 PM
juice's Avatar
This is pretty funny. I was driving with my sunshade open, for the first time in about a year, last night. I complained to the girlfriend about the squeak. She thought I was stupid. I am glad that they know about it. Does anyone know exactly how they fix it?
Old Jan 26, 2002 | 06:55 PM
H@mmerm@n's Avatar
My other car is a 350Z
They may lubricate the rubber seal around the moonroof, or apply a thin layer of teflon tape around the permiter of the moonroof opening where the rubber seal contacts the opening.
Old Jan 26, 2002 | 09:21 PM
Jens H.'s Avatar
retired
Some words of advice about bulletins.These things exist solely to provide service departments with information and instructions on how to correct common problems while the vehicle in question is under warranty.If you elect to print this list out and present it to your dealership with instructions that basically say fix all this stuff you may be surprised to find out that just because the bulletin does exist does not mean it will apply to your car.Some reasons why are as follows,the problem does not exist on your car nor was it confirmed to exist by dealer personel,the bulletin was already completed previously.Bulletins are published as an aid to the service department but they should never be viewed as recalls for instance.A recall is a repair that is required to be done regardless of wether the problem it corrects exists in your vehicle or not,a bulletin is merely directions for common problems that may exist for which there is a known cure.So if you see a problem that is covered by a bulletin by all means tell your dealer about it ,but if you see a bulletin and your car does not exhibit the problem then they will most likely not do anything.Jens
Old Jan 27, 2002 | 11:13 AM
CO-CL-S's Avatar
Re: yeah
I had mine replaced last summer, not retracting due to the belt folding over as it went through the guide and the retractor not strong enough to overcome it. They replaced everthing, belt and retractor. Worked pretty good for a few months, but the last several months it has been getting worse (fails over 70% of the time, unless I hand guide the belt). I may try some "starch" or something to stiffen the belt where it first goes through the guide?
Old Jan 27, 2002 | 11:49 AM
Jens H.'s Avatar
retired
Do NOT apply anything to the belt ,no lubricants no starch and only clean them per the instructions in your owners manual.These belts as far as I have seen require some help from you to retract.Virtually all of the CL's I have seen are the same in this respect.I do not much like it either but this is apparently the way they are engineered so please NO fooling around with this most vital piece of safety equipment in your car.Jens
Old Jan 27, 2002 | 07:37 PM
Zapata's Avatar
Cost Drivers!!!!
Re: yeah
Awe man somebody get rid of this dudes pics in his signature. I thought Soopa was going to disable this feature.
Old Jan 28, 2002 | 02:39 PM
CO-CL-S's Avatar
So we are to accept that the seat belts do not retract on a regular basis? I would think Acura would be doing something to correct it.
Old Jan 28, 2002 | 04:20 PM
WebToker's Avatar
HMMMMMM...
Old Jan 28, 2002 | 04:31 PM
NOLACLS's Avatar
Originally posted by NOVAwhiteTypeS
For me
Do you know what the VIN # is...I am having the same problem I think.
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
JOE COOL
2G RDX Problems & Fixes
Sep 24, 2015 07:15 AM
