holding screw on the rotor
Old 07-16-2009, 09:44 AM
gogozy's Avatar
i want to replace the front rotor on my tsx and so pick up 2 from Canadiantire, when i open the box i do not see 2 rotor holding screw holes. is this normal not to have holding screw hole on the after market rotor for tsx?
thanks!
Old 07-16-2009, 10:09 AM
andrew070489's Avatar
on my tl only the rear rotors had the holding screw. the front were different, im sure yours are similair if not the same.
Old 07-16-2009, 10:17 AM
PACman's Avatar
thanks!
Yes, it's normal. Those small screws are to hold the rotor in place, but they don't serve any performance issues. It's perfectly fine to have a rotor that doesn't have those screws holes.
Old 07-16-2009, 11:15 AM
TodaSi's Avatar
Those little screws are a PITA, I've taken them off and threw them out whenever I put new rotors on my Hondas/Acuras, which has been what, 8 cars
Old 07-16-2009, 11:53 AM
gogozy's Avatar
reading reply and look like those screw are not needed!!
thanks to everyone's help!
Old 07-16-2009, 02:33 PM
CL9 ABP
lcrazyaznl's Avatar
They just help hold it in place.
Too many people strip them even with an impact tool they still managed to strip.
Old 07-26-2009, 03:38 PM
mars's Avatar
Hi All,
How does the Rotor holds to the Axle with out those screws ? I mean the lug nuts will be there but when you remove the wheel without these screws won't the Rotors come loose when we remove the wheels ??
Mars
Old 07-26-2009, 06:29 PM
PACman's Avatar
Originally Posted by mars
Hi All,
Mars
The brake caliper will hold the rotor.
MrHeeltoe
20
02-23-2023 01:54 PM
08KBP_VA
10-22-2019 01:55 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: holding screw on the rotor
