Hacking the '06 TSX Navi System
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
Hi everyone,
I am new around but through all of my searching these forums and other acura forums, I was not able to find where anyone has successfully extracted the bin files form the white nav disc that comes with the 06 TSX. Since I just bought my car last weekend, I was anxious to get in there and use the tools released by Bysin to change the startup screen image. However the bin formats changed in the 06 and those tools are no longer compatible. So I had to figure it out all over again for the 06.
Let me know if you are interested in this app so I can get an idea of how many people may use it. I don't want to take all the time getting it user friendly if no one really needs it.
I am still working on it and will have some tools ready very soon, but here is a preview of the 3 startup images I found in 06Touch2.bin and 06Jog2.bin (both bin's have the same images) Once I get the app finished I will be testing out replacing the startup image on my car. Right now I dont know which bin is actually used since they both have the images.
Here are the images that I found... I dont remember seeing the first one before from the 04 or 05 but I could just be mistaken.
![](http://www.angrycamel.com/06TSX/Opening2.png)
![](http://www.angrycamel.com/06TSX/Opening3.png)
![](http://www.angrycamel.com/06TSX/Opening4.png)
![Thumbs up](https://acurazine.com/forums/images/icons/icon14.gif)
hmmm... I accidently must have made a frown face on the first post of this thread. lol It really should be more like...
Mods can you fix the first post to a thumbs up or something?
Removing the nag screen is one of my goals. I would also like to add modules to enable more multimedia functionality.
Has anyone ever played with the pc card slot, gotten the nav comp on a network?
Originally Posted by angrycamel
Hi everyone,
https://acurazine.com/forums/showthr...&page=50&pp=25
to go even farther, i copied/burned a copy of my navi disc and i'm using the burned disk instead of the original.
Thanks again for the link,
AC
Ozhonda member :P
multimedia function!?!? damn interested~!!! keep us inform of this please
btw will this work for me is well? i got Honda Euro CL9 with satnav in australia... hope it does
GOOD LUCK MATE~!!
GOOD LUCK MATE~!!
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Needs more Lemon Pledge
Angrycamel,
You will acheive deity status if you can accomplish all of this.
What software did you use to break open the files on the DVD? The reason I ask is that I have access to some pretty powerful software for seeing inside volumes, files, phyysical devices, etc... So if you need to, you can send me an ISO, or a file and I can try to extract portions of it, although I am not talking about a code compiler, etc... Data recovery type stuff. Let me know.
Well I started to add a very quick and simple gui to the cmd line apps that I found in the wince stuff. I uploaded it so you can take a look if your interested. I will extract the contents of the bin out to a folder. I stopped working on it since the guy above showed me it was possible with the tools you guys have already. (I missed that somehow in my searching.)
Anyways, here it is if your interested. All its really doing is using cmd line tools that I found online to convert the bin to an nb0 file then extract that.
Be aware this may have some bugs in it. Backup your bin before playing around with it.
http://www.filefactory.com/file/8da0a1/
For anyone who has burned a new disc with success on the 06 nav system, can you post your burning software as well as disc type and manufacture? I have tried three different types of cdr's as well as one dvd-r. I have also tried both Nero and Windows cd burner built into the os.
Here is what I am doing and the results I am getting:
I burn my new disc with the modified bin as well as the other files required per this little howto.
Next I start my car with the original disc in the nav unit and the nav unit's little door closed.
Once the nav has started I hold the menu/map/cancel buttons down for fize seconds then select the version screen
Once on that screen I can go to my trunk, open the little nav door, then eject the stock disc. The nav system continues to run just fin sitting on the version screen with only the two available buttons, download and return.
It is at this point that I have tried a couple of different methods to no avail. The first time I just inserted the new disc (CDR burned with nero) and it instantly restarted the nav system then presented a contact dealer screen (bad disc) on startup.
The second time I tried burning a CDR with the windows os and I put it in on the version screen again and it behaved exactly the same way.
The thrid time I tried was with a DVD+R disc (Verbatim) burned with nero as a data dvd disc at 4x. I went to the version screen, ejected the disc, then I went to the screen in the car and hit the download button. I rushed to the trunk and inserted the dvd+r disc... it said, please check the disc and even after re-inserting the stock disc required me to restart the car to get the navi back.
Does anyone have any suggestions on types of discs that I can try or a method that I am not doing correctly? Any help is greatly appreciated.
I used verbatim CD-R's and nero to make mine. You might be doing things in the wrong order...Once you cut your car on, don't hold the three buttons. The first thing you should do is put the cdr in the drive then hold down the three buttons. You probably won't have time to do it in one step so cut your car on, pop in the cd-r..cut your car off then back on then hold down the three buttons and see what happens.
Summer is Coming
cycdaniel
12-17-2019 10:58 AM
ivegotthenav
09-11-2015 07:51 PM
Gianni Formica
09-07-2015 08:28 PM
yahelou
09-06-2015 09:12 PM
