Gear Shift Light - Is it supposed to light up
Old Sep 4, 2007 | 03:51 PM
stroodlebug's Avatar
3rd Gear
Hi,
Just bought the 08 TSX on friday. Monday I noticed the Gear Shift (AT) does not light up when a gear is selected (lights up fine on the dash, but not next to the gear shift itself). I was wondering if possibly the fuse is blown, or if it just doesnt light up in this model?
stroodlebug
Old Sep 4, 2007 | 04:24 PM
RGlesing's Avatar
Unless they have changed it in the '08 model, then no it doesn't light up. You have to look at the dash.
Old Sep 4, 2007 | 05:18 PM
jlukja's Avatar
Old Sep 4, 2007 | 07:58 PM
3rd Gear
well...it just lit up today evening. I had to turn the lights on, and the gear shift lit up..not sure if this is supposed to be this way, or if i was poking around and managed to turn somethin on ???
Old Sep 5, 2007 | 01:08 PM
RGlesing's Avatar
Are you referring to some internal lighting of the gear selection, or are you talking about the overhead (blue) lighting which shines down on the shifter?
Old Sep 5, 2007 | 08:38 PM
3rd Gear
I'm talking about the P,R,N,D,D3 marked next to the shift.
Old Sep 5, 2007 | 09:43 PM
rabican's Avatar
just leave your lights on 24/7, it looks hot and they turn off automatically when you get out of the car.
Looks pimp when you unlock/lock your car and it turns on the lights
Old Sep 6, 2007 | 07:13 AM
RGlesing's Avatar
Yes, those letters do light up, though you can't really see it in the daylight.
Old Sep 6, 2007 | 07:41 AM
TheDukeZip's Avatar
Old Sep 6, 2007 | 08:28 AM
thevikas87's Avatar
Your mom is in
LOL i recently started doing this with my CLS...
Old Jun 16, 2008 | 10:31 PM
lcrazyaznl's Avatar
CL9 ABP
Bring this from the dead does anyone know what bulbs are needed to replace the lights?
Old Jun 18, 2008 | 03:46 AM
lcrazyaznl's Avatar
CL9 ABP
Okay so i took apart my gear shift today, found the little light bulb on the left side.
Its a plug and play, it uses the same bulb in the glove box.
Pretty much pull up the center console then pull. on the silver plate, and on the middle left side you can see a little wire attached to it.
There you wiggle out the bulb and check if yours is burnt. Mine was black, i'm getting a new bulb later tomorrow.
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
HeloDown
Sep 8, 2015 06:51 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
