engine light
engine light
My battery was disconnected in my 2004 tsx when the battery was hooked back up my check engine light came on and stayed on...is this normal or should i bring the car to the dealer to get checked? Please help!!
If nothing has changed, removing the negative terminal again and then installing it can reset the light. If after driving a few miles and the light turns back on, there's something wrong in which you should use a OBD scanner to check the code.
Sorry thats 15810...is this a part or a censor im really trying not to blow up on the repair guy but i really thing he is not being honest because im a woman...im just trying to educate myself...thanks
There is no code I could find resembling 15810. All engine codes are Pnnnn, where n is a number 0-9. If you can get correct code, write it down and post here for possible help.
If you're not happy w/ repairman's attitude, find another. Suggest checking w/ auto parts store and Angie's List.
good luck
good luck
HeloDown
09-08-2015 06:51 PM
