ABS code help needed.
Old May 13, 2015 | 03:35 PM
Heavymental's Avatar
4th Gear
got a 2006 TSX, VSC, ABS, BRAKE are all on. I manually checked the ABS codes, im getting 5-4. This should be the pump.
was wondering if there is a relay or fuse for the ABS system?
Old May 14, 2015 | 02:12 PM
4th Gear
does anyone know how to remove the connector on the VSA ABS modulator?
Old May 14, 2015 | 04:26 PM
TexasHonda's Avatar
From shop manual (sorry I can't print a file w/ my manual), fault is either:
1) a ground fault to the VSA Modulator Control Unit, (Pin 47 of 47 pin connector, right lower corner pin looking at connector from wire side). Check for ground to this pin. If ground is missing, the repair ground wire.
or
2) VSA Modulator Control Unit fault. Reset VSA Modulator Control Unit (see attached manual procedure) and drive. If code returns, then replace control unit. See ebay and car-part.com for a used unit.
Suggest getting your own shop manual to have pin diagram and other info. Check ebay and automanualsource.com.
good luck
TypeS860
Jan 10, 2026 11:11 AM
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
