Does the TSX have as many little problems as the TL????
I want to get a TSX within a year. The number one more concern to me when I purchase a car is reliability. All the cars my family and I had owned had absoultely no problems. I never had to go to a dealer to fix a any warranty things.
I've browsed the TL forum and man there are sooooo many little annoying problems with the TL that some people traded it in cuz they were sick of these problems not getting fixed.
So is the TSX more reliable and problem free then the TL????
To my observations btw the forums the TSX seems to be reliable.
What do you guys think? I'm sure it helped the TSX in terms of reliablitiy that its built in Japan.
The same should apply to the TSX -- less problems with the 2005's compared to the 2004's.
Just dial 1911
1 Post
Originally Posted by Benz_05_TSX
I haven't had a probelm except rattles in the 05 yet..... and let's hope it stays that way....
the 04 had a little more problems with the center console and transmission~ (someone blew theirs)~
Unless its a consistant problem, its not a problem at all...
Man the research I have done on this car says it is very reliable. Not sure what you want? Cars sometimes need fixed. Depends a lot on the driver as well. Some people use brakes and wear them out in 20K miles, and some can go 70K on a set. I would want to buy a used car from the guy that can get 70K on his set. Probably has had less problems on his car as well.
WELL .... in today's auto mkt, no one car MFR have trouble free cars and trucks. Car prices had not really gone up that much during the past few years, and have to add more safety features and other fancy stuff for consumers.. To do this it forced most MFR to cut quality, what i call cut corners to offset the added stuff cost to the car without increasing the price to shock consumers. I will not buy first year production models on any brand again. it gives us the bugs and or minor problems. but all sve advisors told me tsx have less problems than TL. and TL is made in usa, " hello ! " and tsx is fully Japan. parts and labor on my 04. it is pure 100%. no mix and match. but i have little rattle problems, and pwr window's door pannel rubbing against window while go down or up. engine and trans is ok. i baby the car. i change my trans fulid at every 12k, air filter at every 10k, oil change at 2500 miles, coolant at 30k, brake fluids bleed or flush at 30k, air condition filter at 15k, brakes when sensers start have noise, and that is about it. but the clock display went out on me at 27k under warranty, and my warranty expires 100k
everyone have their little story on trans problem, this and that. sometimes is luck but also based on how the driver take care the car and driving it. if u drive hard on it, and step to redline each gear .. how it last? even a ferrari will die on you if you dont change fluids.
mind as well.. " dont take shower everyday"
Canuck
Originally Posted by joerockt
??? One person blows their tranny and thats a problem? Um
These issues were disappointing as I had expected some improvement in the 05s. But they have not been bad enough so for me to go to the dealer and have them possibly make stuff worse by ripping the dash apart, etc. The camber issue wasn't a big deal b/c I knew I was going to lower my car and get a rear camber kit anyway.
I think the truth of the matter is, with the internet, some people are more vocal about problems w/ their cars and it gives the appearance that a car is filled w/ problems. People hardly ever post that their cars have been problem free. To compound matters, when others read about certain rattles and issues, they go looking for them in their own cars. This clearly happened to myself as I noticed the problems in my own car the first week I owned it b/c I was specifically looking for them. Now, I don't notice the rattles as much.
If all you care about is reliability, I would recommend a Honda civic. Order with manual windows and locks and no A/C.
You increase the chances of having a problem when you increase the complexity of the vehicle. Based on this logic, I would expect the TL to have a few more issues than the TSX, and the new RL to have more issues than the TL.
Just my experience as an electrical engineer...
I never had problems with my center console.
There were a few recalls with the TL i believe. The biggest one was probably with the drive shaft balancing issue. It would cause a huge shimmy. Then there was a recall with the tires flatspotting and shimmying on the highway. Then i think there was even a transmission recall.
But these were mainly for the 04 models. I believe most of these problems were fixed in 05. Rattles are normal in a car that is built solid and with tight tolerances. There's no way to guarantee every single car coming off of the assembly line wont have them... they just have to fix them as they turn up.
The closest you will ever get to no problems is Lexus. Problems per 100 vechiles study they always have less then 100 problems/per 100 cars.
All other manufactures have over 100.
I think Acura was 104 problems per 100 vehicles.
This was a JD power survey a year ago. Forgot the name.
I have two of the most common problems for the TSX - rattles and brake rotors warping. I have the dealer fix both problems and the car now drives like the first time I got it. These issues are very minor and shouldn't sour you from considering the TSX.
Originally Posted by narci
there was a service bulletin to acura dealer with VIN ranges for tranny replacement.
Also remember that those JD Power Initial Quality surveys are pretty subjective. I don't believe for one second that Hyundai makes a better car than us. Yet there there they are at the top of the heap. Thing is, nobody expects a great car from Hyundai, so when they get their cars, they say "hey this is not so bad, and it's great for the money...." They might have 150 problems per vehicle, but in their minds, it's not so bad!
The original poster is (IMO) setting himself up for disappointment because no modern car can live up to "perfect" expectations but Honda/Acura and Toyota/Lexus are pretty close.
Canuck
Originally Posted by Colin
Oh my god, welcome to March 2003! See here for my posts on this subject . This is not an issue now, nor is it related to the topic at hand. IMO, the TLs have a few more squeeks/rattles than on the TSX, but on average they are both pretty good. It all depends on how picky the particular owner is.
You know? whatever happened to the good old days where one would buy a brand new car and never had to bring it into the dealer especially when it was new? lol
Oh man... i guess times have changed as cars have newer features and are getting more complicated.
the point i was trying to make was that it wasn't just 'one' person who blew a tranny and yes, i know it was 2 years ago.
Alin10123, those days never existed. The only difference is that there was no Internet for people to gather and 'compare notes"
Have camera, will travel
Originally Posted by AlterZgo
Exactly my point above. But, I do agree that the newer cars are MUCH more complex which results in much greater possibility for problems.
Originally Posted by xjdmb16a2six
^^^ thats true. thats why benz and bimmers have so much problem. too much electrical stuff and computer stuff.
cycdaniel
12-17-2019 10:58 AM
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
IndycarFaster
09-11-2015 02:52 PM
