Did I hurt my car??
Did I hurt my car??
I have a new to me 2005 TSX AT with 2300 miles on it. I was using the sport shifter and was supposed to go into third but accidently shifted into first again. The car stuttered around 7100rpms and I noticed my error and corrected it. All seems good and running great I just hope I didn't hurt my car.
It shouldn't go in to first if the rpms are too high. If it does, there's a problem! You shouldn't be able to shift in to 1st at like 80mph. It won't let you! If it does, not goody! See dealer fo shizzle!
You didn't hurt it. The stutter you describe is probably the rev limiter cutting fuel to the injectors. I am a little confused how you "miss-shifted". The SS is sequential. You can't accidentally skip a gear.
Originally Posted by jkneff
It is an AT and instead of pushing forward to go into third I pulled it back and went into secound gear
8th Gear
If you have an AT why would you want to be shifting ^_^ I bought my AT just because i am too lazy to shift
When you were in 2nd about to shift to 3rd (supposingly), what rpm were you at? I accidentally shifted from 3rd (very close to redline) to 2nd in a loaner TL, and the check engine light came on. I shut the car off and restarted, and the check engine light went away.
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
