Complete TSX LED replacement guide (link on pg. 17)
Old May 11, 2005 | 10:14 AM
  #81
GrOD's Avatar
Thanks! How much of an improvement are yours over the OEM?
Old May 11, 2005 | 12:55 PM
  #82
CCColtsicehockey's Avatar
is the illumination better with the LED reverse lights or does it just look better with them in because the white color is better
Old Jun 11, 2005 | 11:23 PM
  #83
Savio's Avatar
TSX
Which ones should I use for just the doors? I want the blue leds for those?
Would that be the T13-B6 from the reference below?
http://www.e-clipse.net/tsx/lights.html
Old Jun 12, 2005 | 09:08 AM
  #84
moda_way's Avatar
I found the illumination to be better on the ones I did because I turned a 2-stage LED matrix into a single stage... like a break bulb that is always on.
Old Jun 12, 2005 | 09:10 AM
  #85
moda_way's Avatar
Overall, the LEDs are technically less powerful/strong than the bulbs, but I wanted the more deep red color and white for the reverse lights. The only ones I've now kept bulbs in are on the licence plate. For some reason those 194 6LEDs always failed. The subtle bumps in the road evidently played a lot of havic on them.
Old Jun 12, 2005 | 06:28 PM
  #86
dailo's Avatar
I still have my LEDS in, almost a year now. The only big improvement is the reverse LED light. I changed the break lights and they definately look different then the stock and stands out compared to other TSX's, but its your call if the difference is woth your changing them. I wish they were a little deeper red. They seemed like they were before, but now the lights aren't all that deep.
Old Aug 2, 2005 | 12:39 PM
  #87
bigwilliestyle's Avatar
Hey, does anyone know what type of bulbs are in the sun visors?
Thanks!
Old Aug 2, 2005 | 01:00 PM
  #88
moda_way's Avatar
Thanks!
The vanity mirror ones aren't available in any LED size because they are too small, however you could mod'd up a set using some single LEDs. I was going to do this, but ran a test and saw that the light filter on the vanity mirror would pretty much kill any light from a single LED.
Old Aug 2, 2005 | 05:01 PM
  #89
rmpage's Avatar
Drives With Hands
Originally Posted by 340HP
Waste of money.
Did the mod, the LEDs are not bright enough (except for backup white lights), signal lights flashed too fast (different resitance?), two LEDs burned out, took out a fuse in the process, had to go back to incandescent.
Bleh.
You found the tail/brake lights to be too dim? My LEDs are perceptibly brighter than the incandescents they replaced were. Not only that but they are a much deeper red color, unlike the filtered orange-ish hue of the incandescents.
To each his own, I'm just surprised you found them too dim. The matrix bulbs are hella bright to me.
Old Aug 2, 2005 | 08:27 PM
  #90
Yeah, I don't think the 15 LED Matrix's are bright enough either. Had them for my backup lights for a while.
Long story, but some weekend a couple months ago, ended up on a long narrow one-lane dirt road in Maine; road came to a massive lake-size puddle, couldn't go around or through (or turn around), had to drive in reverse for about a half-mile, couldn't see shit. My friend had to hang out the window and direct.
Though it does look pretty cool, I'm gonna stick with the incandescents for the exterior lighting.
Old Nov 6, 2005 | 01:10 AM
  #91
ILoveMyHonda's Avatar
17781708
So has anyone done a LED conversion on their tails that are NOT just bulb replacements. I have tried two different companies of 7443 LED bulbs and all have been to dim for daylight driving.
I have been contiplating diassembling my tails and retrofittin them with multiple single LEDs glued into the housing. But has anyone else done this mod I'm curious. If not I just might be the first......
Old Nov 6, 2005 | 01:39 PM
  #92
iNteGraz92's Avatar
LED drop in bulbs suck. i think those round truck LED replacements would look much better inside the tsx tails. but then you'd have to open up your lights.
Old Nov 6, 2005 | 02:42 PM
  #93
Powered by Honda's Avatar
LINK DOESNT WORK!!! Help!!!
Old Nov 6, 2005 | 06:06 PM
  #94
wclark's Avatar
ur link is broken
Old Nov 7, 2005 | 01:06 AM
  #95
17781708
Thats sounds like an idea that I might try, do you know anywhere i can get these?
Old Nov 7, 2005 | 07:22 AM
  #96
Tintin's Avatar
link doesnt work....
What is the point of having LED rear lights?
the original brake lights and reverse and signal all works fine and have been for the longest time. is making them brighter going to make it safer to drive at night because people will notice you!?
Sorry if thats a dumb question, i know nothing about this topic and would like to.
Old Nov 7, 2005 | 09:48 AM
  #97
dontcare4urshyt's Avatar
06 US Accord has LED tailights. Anyone know if the 06 TSX has them?
Old Nov 7, 2005 | 01:54 PM
  #98
rbf351's Avatar
Registered User
LED's light up fast than regular bulbs, which would mean the person behind you can react that much quicker
Old Nov 11, 2005 | 04:55 PM
  #99
MikeMa's Avatar
No Longer a Poseur
Has anyone taken apart a 2006 RSX Type S rear tail light? It's supposed to be LED, and it's got round lights like the TSX.... I wonder how that thing is built (if it's a single LED bulb or if it's multiple bulbs like in the TL?
Just a thought....
Old Nov 11, 2005 | 05:07 PM
  #100
HoRRo's Avatar
iVTEC no koe
Just a thought....
The most "LED" it would be is just a bulb with LED cluster on it. Definitely not an LED setup like the new Accord.
P.S. The website doesn't specifically point out that it's LED Tail lights, so it might even be just a regular bulb.
Old Nov 11, 2005 | 05:51 PM
  #101
TSX7's Avatar
How difficult is it to replace the bulbs above the license plate? Do you go at it from the inside or the outside?
Old Nov 11, 2005 | 05:54 PM
  #102
hans007's Avatar
the main advantage i think of LED tails is well. it looks cooler.
most people can't react fast enough to it lighting up more quickly. it is a bit brighter too on some cars i suppose.
Old Nov 11, 2005 | 05:58 PM
  #103
moda_way's Avatar
Inside. Take the carpet off the trunk lid and you pull out... for lack of a better term, a connector with the bulb in it.
Old Nov 12, 2005 | 12:42 AM
  #104
slats's Avatar
I just did this with a super white 6-LED bulb from superbrightleds.com and it looks great.
Old Nov 12, 2005 | 12:28 PM
  #105
17781708
Any one have any pics of their LED bulbs in brake lights? I'm curious as to how everyones set up looks. I have tried a few and either they weren't visible in the day or all I got was a red dot right in the middle of the brake lens since the light only shines in one direction.
Any other pics would be helpful.
Old Nov 12, 2005 | 12:37 PM
  #106
moda_way's Avatar
Here is my car, which used to be on that link in this thread. Left side is all LEDs and right side is standard bulbs (including the license plate light). The only light that aren't LEDs on my car are the turn signals b/c you need a resistor with that to make them work.
Old Nov 12, 2005 | 03:03 PM
  #107
the problem with it is though is they do not aim backwards at the reflectors in the housing and thus provide as much lights. I still want to find some xenon white bulbs that dont melt the rear housing.
Old Nov 12, 2005 | 03:43 PM
  #108
xenonhid's Avatar
CGP Ebony
I agree, Will JDM put out LED tailights in the future? b/c I know alot of TSX owners would buy them
Old Nov 12, 2005 | 03:45 PM
  #109
moda_way's Avatar
They actually do make a set now that does focus more light into the reflectors. I have the type that do not.
Old Nov 12, 2005 | 11:20 PM
  #110
drigo's Avatar
since the led guideline bondgirl made no longer works for me..can someone please tell me what type of bulb the liscence plates lights are? i'd like to change them to the bright white(flourescent white) also where i can get the bulb...thanks
Old Nov 13, 2005 | 10:50 AM
  #111
drigo's Avatar
^^^anyone?
Old Nov 13, 2005 | 12:23 PM
  #112
moda_way's Avatar
Originally Posted by drigo
^^^anyone?
use the 164/198 LED type from superbrightleds.com
Old Nov 13, 2005 | 02:21 PM
  #113
Sebo's Avatar
what LEDs did you use, moda?
which are the deep/bright red?
what about the spoiler brake light, you plan on doing that? i think an led would look good there too.
i want to do all the lights including the turn signal.. wonder if i can find a shop with experience with modding a car for LEDs.
Old Nov 13, 2005 | 03:29 PM
  #114
MikeMa's Avatar
No Longer a Poseur
Sorry if you meant something else (like changing the colour of the spoiler's brake light), but the spoiler already has LED lights in it.
The centre "high mounted" brake light in the rear glass is traditional bulbs, though.
Old Nov 13, 2005 | 03:45 PM
  #115
17781708
thanks for the pics moda_way. looks like the same result i had with mine. I also treid the ones that shine sideways around the edge of the bulb, but to no avail they just don't do the same job as filament bulbs.
BTW, have you ever looked at your LED's during daylight time? Are yours still visible enough, cuz i know mine weren't from even about 100ft. away
Oh well guess I'll be working on that LED tail light retrofit
Old Nov 13, 2005 | 03:48 PM
  #116
drigo's Avatar
thanks...is it fluorescent white? also..any chance i can get them locally like in an automotive store? thanks again
Old Nov 13, 2005 | 03:52 PM
  #117
drigo's Avatar
did you mean 194/168? thats what i saw on the website..
Old Nov 13, 2005 | 04:27 PM
  #118
moda_way's Avatar
I believe the spoiler is already LEDs, so I do not plan on doing those.
All of mine came from superbrightleds.com and the only thing I did was modify the reverse light. At that time I had to buy a 2 stage and modify it to be single stage, so it is extra bright white. The rest are the standard replacements. In the trunk, that bulb was a 168/194 and I solidered 2 of them together so that the trunk was illuminated to my liking.
Old Nov 13, 2005 | 04:28 PM
  #119
moda_way's Avatar
As I recall, I have the same effect in the daytime. It hasn't been an issue to date as the spoiler leds are bright enough in stock format.
Old Nov 13, 2005 | 04:30 PM
  #120
moda_way's Avatar
Automotive stores charge $$$$$$ for them.
