Complete TSX LED replacement guide (link on pg. 17)
*drum roll*
The TSX LED replacement guide can now be found on my personal server here:
http://tsx.hhsn.net/leds/
Does anyone have a copy?
I remoted into a computer at work and the page loads fine.http://tsx.hhsn.net/leds/
Try again maybe?
A while back I was actually going to write up a detailed guide for this including which bulbs worked well or burned out for me in the past, but I never did because we already have one
But I can list some quickly now for you:
Dome/Map (3 bulbs total) = DE3175 is the code. They are 30mm or 31mm festoon bulbs.
Door Courtesy, License Plate, Trunk, Parklights, and Taillights = 194/168 wedge bulbs. A lot of sites call them '921' bulbs or 'T10' bulbs too.
Cubby/Glovebox/Gear Shifter = #74 wedge bulbs
Reverse Lights: 7440 wedge.
There is about it for LEDs, but let me know if you want the sizes/codes for other lights that I didn't mention.
Here's a few sites:
http://www.automotivelightstore.com/...bsbymodel.aspx
http://autolumination.com/194.htm
http://autolumination.com/festoon.htm
http://autolumination.com/74.htm
http://www.superbrightleds.com/cgi-b....11688&next=50
http://superbrightleds.com/cgi-bin/s...gi?product=CAR
Here's a few sites:
Hi everyone, I just replaced (almost) all of my lights with new SMD LEDs. Here's some pics.
Cabin interior (no flash) with 3x 1.5W 75 lumen festoon LED bulbs. The entire front is illuminated from these 2 "map lights" bright enough to find small crumbs on the floor mat.
Boot with 2x 1.5W 75 lumen wedge LED bulbs. Lots of light with very little power.
Front parking light with 1x 0.75W 5-LED Vehicle Signal Lamp Bulb (fill flash used in this pic so you can see the housing... and bug splatter)
Tail lights. All LED now. Indicator and Reverse with white T20 2.5W 5 x 9518 Car Turning Signal Light Bulb. Outer brake light (dual illumination level) with red T20 2.5W 5 x 9518 Car Brake Light Bulb. Inner brake light with T10 0.75W 12V Red Light 5-LED Car Turning Signal Light Bulb. License plate lights replaced with 2x T10 wedge 1.5W 75-Lumen White LED Light Bulbs.
Flash used in this pic so you can see housing and more importantly the LED bulb clearly visible in the reverse light. These are modern flat SMD LEDs - not the tube style.
miked8887
Oct 14, 2008 02:05 PM
